planetgaz Occasional Visitor
Posted: Fri Oct 27, 2006 12:39 am Post subject: TT One V2 Automatic Switching to Day/Night Colours |
According to the manual, I should be able to go to Brightness Preferences and select an option to automatically switch to night colours when the in-built ambient light detector thinks its dusk.
All I see on the Brightness Preferences screen is the option to set the day and night brightness levels via two slider controls that control the percentage, there's no other options available.
Has anyone else managed to enable this feature on TomTom One V2 ?
(It's using firmware 6.501 which I believe is the most up to date for this model) |
timber Frequent Visitor
Joined: Jan 18, 2006 Posts: 422 Location: Wild and Windy SW Scotland UK
Posted: Fri Oct 27, 2006 12:56 am Post subject: Re: TT One V2 Automatic Switching to Day/Night Colours |
planetgaz wrote: | According to the manual, I should be able to go to Brightness Preferences and select an option to automatically switch to night colours when the in-built ambient light detector thinks its dusk.
never looked at the manual but have just checked my TT1V3UK and no dedector exists. I use the following http://www.webazar.org/tomtom/suntime.php?lang=uk |
Posted: Fri Oct 27, 2006 1:12 am Post subject: |
Thanks for that Timber, I'll give that a go, sounds like that will achieve the same thing.
Still strange why TomTom suggest it can be done through a setting, check out Brightness Preferences under Preferences on the manual here:-
http://www.tomtom.com/lib/doc/one2006/refman/TomTomONE_EN.pdf
Cheers. |
trevor.dowle Lifetime Member
Posted: Fri Oct 27, 2006 1:50 pm Post subject: Re: TT One V2 Automatic Switching to Day/Night Colours |
never looked at the manual but have just checked my TT1V3UK and no dedector exists. I use the following http://www.webazar.org/tomtom/suntime.php?lang=uk[/quote]
This looks as if it might be useful although I'm not sure if I fully understand the process. If you have got it working, is it possible for you to elaborate on the installation process please? _________________ Regards
Trev Dowle
TomTom 730 T |
Posted: Fri Oct 27, 2006 2:34 pm Post subject: Re: TT One V2 Automatic Switching to Day/Night Colours |
trevor wrote: | This looks as if it might be useful although I'm not sure if I fully understand the process. If you have got it working, is it possible for you to elaborate on the installation process please? |
As with any changes to your gps make sure you have a full backup before altering/adding anything
Download the zip file and unpack.
Place the cab and toc file in tomtom home download folder.
Use tomtom home to install the files.
create a text file called cleanup and place the following text in it daemon|suntime/suntime|
Place the text file in the root directory of your sd card.
Restart your gps you should see suntime program starting up in the top right hand of your screen (you will not see this message again under normal operation).
It requires to have a valid signal from a satellite to carry out the change from day to night and back the software picks up the time signals.
You can alter the gmt setting and also to twilight i'll leave this out for the moment |
Posted: Fri Oct 27, 2006 6:36 pm Post subject: Re: TT One V2 Automatic Switching to Day/Night Colours |
timber wrote: |
You can alter the gmt setting and also to twilight i'll leave this out for the moment :!: |
Thanks, even with my limited ability I should be able to manage that. I'll give it a try at the weekend. (I may be back for help!) _________________ Regards
Trev Dowle
TomTom 730 T |
lbendlin Pocket GPS Staff
Posted: Fri Oct 27, 2006 7:23 pm Post subject: |
The ambient light sensor indeed is a very handy feature of the x10 GOs. Difficult to understand why TomTom have not included it in the TT1V3 _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Fri Oct 27, 2006 8:54 pm Post subject: |
Yeah, especially when their manual suggests they have included it !!!! |
wibbly Frequent Visitor
Posted: Sat Oct 28, 2006 3:54 pm Post subject: |
Even without the sensor, a software solution like the 3rd party one listed would have been useful... |
Osmosis Occasional Visitor
Posted: Tue Oct 31, 2006 12:31 am Post subject: Suntime conflicting with menu options? |
Downloaded Suntime a couple of nights ago and am wondering if the automatic check every minute causes the TomTom One (new edition, app v6.5) to lose touch of where you are in the menus. For example, I'm usually finding that as I'm typing in text for a POI or waypoint, it removes the whole line and I have to start again, or it thinks I've hit a different button on the screen. This is intermittent, which makes me think it could be Suntime, as I used the TT for two days when I first got it without a glitch.
Anyone else noticed this? I might have to remove Suntime and see if I have any problems for a while, then load it back on again.
Great little programme though.
Osmosis
TomTom One (New Edition)
Application version 6.5
Suntime 1.1 |
Posted: Tue Oct 31, 2006 8:58 am Post subject: |
That would be a shame. I'm just trying Suntime. Please keep us posted if removing it fixes the problem... |
MarkHewitt Frequent Visitor
Joined: Nov 16, 2004 Posts: 1077 Location: Chester-le-Street & York
Posted: Tue Oct 31, 2006 11:36 am Post subject: |
Is it possible to set the update rate to (say) every 5 or 10 minutes rather than every minute? It wouldn't make the menu problem go away but at least it would make it much less likely. |
Posted: Tue Oct 31, 2006 12:14 pm Post subject: |
Thanks for replying, guys. Have you installed Suntime and noticed any difference? I kind of hope so, as it means it's not by brand new TT. I have appalling luck with electronics.
I've had a look in the three files needed for Suntime but I suspect the time interval is in the .cab file, which doesn't show normal text once opened in a text editor.
I think I've e-mailed the developer (I say this because the site is in French), and have asked if he knows if this is an issue and can the interval be changed. I'm not expecting a reply anytime soon. I may have to get a French guy I know to re-write my request.
I'll keep you posted but please do run your own tests too. |
Posted: Tue Oct 31, 2006 12:33 pm Post subject: |
Sorry to be posting so close to the last one.
I've fired up the TT and run a quick test. By looking at a clock when I turned it on I was able to guess when Suntime would run a check (every minute).
I then went to Change Preferences _ Set owner... and began typing in some details. This meant I should be typing as Suntime refreshed itself. Low and behold, every minute, for 3 minutes, my line of text was removed or defaulted back to the original. This was almost to the second I'd estimated ST to be active.
I then removed ST and tried again. This time the night colours stayed active and as I typed in my owner details, nothing refreshed, moved, or defaulted. So my own 'objective' test shows it's a bug in Suntime, or a conflict. |
Posted: Tue Oct 31, 2006 12:46 pm Post subject: |
Shame. TT One needs something like this... Hopefully they'll fix the bug. Sounds perhaps like they're re-enforcing the display setting once a minute regardless of if it's already set the way it needs to be...
Anyway, please let us know here if you get a version that doesn't suffer this problem. |
