MikeGordon Lifetime Member
Posted: Sat Oct 28, 2006 4:40 pm Post subject: Intelligent speed camera warnings |
Is there any chance of the new intelligent speed camera sounds running an TT Nav5 running on a Dell Axim X50?
Mike Gordon |
Posted: Sat Oct 28, 2006 4:44 pm Post subject: |
Mike if you mean the ogg file method of speed camera warnings then it should work as users have confirmed it to work on the following versions TTN 5,0 5,1 and 5,21 - unless you mean something else by "Inteligent speed camera sounds" - Mike |
Posted: Sat Oct 28, 2006 4:53 pm Post subject: |
I downloaded the new POI sounds detailed on the site after checking the s/w version 5.0 (4890), duly renamed the original DATACHK file as instructed, whacked the new file into the folder, renamed that, then allocated the names as per the list displayed. When I hit the test button, I still have the original sounds. Obviously doing something wrong! |
Posted: Sat Oct 28, 2006 5:05 pm Post subject: |
Mike the data.chk method will work fine with your system, did you soft reset the PDA since changing the data.chk file?
I wouldn't bother with the data.chk method these days it is much easier to use the ogg file format (and you can have more warnings) have a read HERE follow the links in Lutz first post in the thread to Rays site for the files you need, or trawl through the thread and on the last couple of pages are some other downloadable voice files from members of this site (these will have been re-named for you, unlike the ones from Rays site which will require renaming to be used) - Mike |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10641 Location: Suffolk, UK
Posted: Sat Oct 28, 2006 5:10 pm Post subject: |
MikeGordon wrote: | ... whacked the new file into the folder, ....
When I hit the test button, I still have the original sounds. Obviously doing something wrong! | Did you put the new data.chk in My Device/Program Files/Navigator?;)
NOT on the SD Card. _________________ Richard
ttrevor Lifetime Member
Joined: Dec 04, 2003 Posts: 540 Location: Sleaford Lincolnshire UK
Posted: Sun Oct 29, 2006 9:31 am Post subject: |
Go the ogg. way soooo much easier than playing with the data.chk file,just put it all on my SD card on my faithfull 2210 and running TT5.10 and it works a treat :D _________________ Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play |
Posted: Sun Oct 29, 2006 3:23 pm Post subject: |
I had not put the datachk file in the correct place, will do so now, and then I will examine the ogg file scenario.
Thanks to everyone for their advices! |
