Pocket GPS World :: View topic - Haicom HI-406 y TTN5 ¿How To?
jmsegov
PostPosted: Tue Oct 17, 2006 9:33 am    Post subject: Haicom HI-406 y TTN5 ¿How To? Reply with quote
How can i configure this device for ttn5 recognize it.
Somebody have this configuration
philpugh
PostPosted: Thu Oct 26, 2006 2:55 pm    Post subject: Reply with quote
You don't say what your hardware is - but assuming a Windows based PDA...
Pair your 405BT to your PDA.
Create an incoming serial port through BT for your GPS (this will be something like COM6 or 7 depending on your device / operating system etc.
Ensure you have the latest version of TT5 for your PDA (V5.21) as this fixed some BT issues.
Take the whole lot outside into a clear area. Turn your GPS on, turn the PDA on, start up TT5 and wait for a GPS fix. Check the GPS status page on TT5 and see if any of the signal strength bars are showing grey bars. If so - all is working and as soon as a valid position is calculated the bars will turn blue and everything should be OK. This can take upto 30 mins for a first time fix.
If you are not getting any connectivity to the BT unit (nothing in the signal strength bars or a failure to connect I would suggest a soft reset of your PDA first and if this fails a hard reset - but you will need to re-load TT5 and any other apps.
