Antoeknee Lifetime Member
Posted: Fri Aug 18, 2006 10:43 am Post subject: Traffic Warning Sound |
Now using Traffic and would like to change the sound for when a route is recalcualated.
Can't seem to find a way of changing it, which either means it can't be done or I'm missing something obvious.
Anyone care to enlighten me? |
tonys66 Lifetime Member
Posted: Fri Aug 18, 2006 11:58 am Post subject: |
You dont say what unit you are using ?? |
Posted: Fri Aug 18, 2006 2:44 pm Post subject: |
tonys66 wrote: | You dont say what unit you are using ?? |
Oops its a TT 500 |
Posted: Fri Aug 18, 2006 7:38 pm Post subject: |
It is possible to do by using POIExtend from HERE your new allert will need to be in .ogg audio file format at the correct frequency (22050Hz) - and you will need to find out which slot it occupies by a little messing around with the file (moving sounds around to find the correct one), its a while since I did this and cannot remember exactly which slot it occupied , if I find anything on my PC later I will let you know - Mike |
Posted: Sat Aug 19, 2006 8:34 pm Post subject: |
Thanks Mike
Reason I'm asking is I've finally chosen to have spoken warnings for the speed cams and of course found that I was getting cam warning when traffic updates.
Suspected that I'd have create my own POI alerts |
