Pocket GPS World :: View topic - camera warning voice problem
tonygold
PostPosted: Wed Aug 09, 2006 6:50 pm    Post subject: camera warning voice problem Reply with quote
weird one this.
i used to have the camera graphics and voice warnings correct, ie the voice warned me of a red light camera or 30mph camera etc. upgraded to a larger sd card and now although the camera graphics show correctly, every voice warning is the same ie "warning gatso ahead speed limit 70mph" even if the speed limit is different or a red light camera etc????
have tried re-downloading the database ov2 fles and re-installing but has made no difference.
any idiot-proof answers out there?
would be most grateful.
cheers.
ps i'm on a tomtom ONE
gb plus map version 571.0
PostPosted: Wed Aug 09, 2006 6:58 pm    Post subject: Reply with quote
Try setting up the Warn When Near POI function again, it is found in change preferences/ mamage POI, you will have to set-up each camera POI file though (all 24 if using the Soeed Zoned file set). Use the Test button to listen to the actual audio before selecting that file - Mike
tonygold
PostPosted: Wed Aug 09, 2006 7:25 pm    Post subject: Reply with quote
sounds a great idea. have just driven myself mad and set them all individually. hopefullly this will sort it. when i update database presumably this will still work and not need doing again??
many thanks for your reply.
PostPosted: Wed Aug 09, 2006 7:53 pm    Post subject: Reply with quote
You only need to configure this once, any updates to the camera locations will use the existing set-up. If you want to see if it is working choose Advanced Planning A to B, and set a departure point then arrival point. Next use Show route demo, set replay speed to 100% - make sure your chosen route goes past a few cameras though - Mike
tonygold
PostPosted: Wed Aug 09, 2006 7:55 pm    Post subject: Reply with quote
yep. just been out. works a treat.
thanks again.
22.055 (29 May 24)
