Pocket GPS World :: View topic - Can I navigate via GPS Coordinates?
db_squash
PostPosted: Sat Aug 05, 2006 10:41 pm    Post subject: Can I navigate via GPS Coordinates? Reply with quote
Hi. I've just bought "Navigate 7" for PocketPC (7.0.990) and - so far -seems OK. I've seen one occasion when I tried to navigate to a specific Britain Post Code (PO1 2LN) that the Ipaq H2210 locked up with a "Calculating..." message. I've email Route 66 support on that one.
Question: I've scanned the manual and find no mention of any means of navigating to a specific GPS set of coordinates. Has anyone worked out whether this is possible? If so - how is it done? (An attempt to work-around the "lock-up issue" navigating via Post Code)
Thanks. Dave
PostPosted: Sat Aug 05, 2006 11:46 pm    Post subject: Reply with quote
Welcome to the forum, nav to a co-ord is not possible as a direct action, but as you have the lat/ long you can create a POI file containing this (and any other locations) each POI within the catagory you create can contain a specific name.
Then you simply tap Nav to/ POI around GPS Position, select your POI catagory from the list (as a tip to make it apear first in the list start the POI catagory with the letters Aa-unique name )
I am not too sure how many POI you can enter into each catagory, but there doesn't appear to be a distance limit to this method, I have been using this Nav to POI option the most as I find the other options are too troublesome in operation, once set the POI file is there for good.
If you need any advice on creating the POI file for Route 66 please feel free to ask - Mike
Edit once Mike Alder to add below:
As for how many POI you can list using my method above, there is no realistic limit you will hit doing this for custom made POI, I have just tried a file test and my unit listed all 2322 entries, they are in the order of nearest to current GPS position first.
db_squash
PostPosted: Mon Aug 07, 2006 12:11 am    Post subject: Reply with quote
Thanks Mike - I'll give it a try....
eirlink
PostPosted: Fri Aug 25, 2006 10:53 pm    Post subject: Re: Can I navigate via GPS Coordinates? Reply with quote
[quote="db_squash"]Hi. I've just bought "Navigate 7" for PocketPC (7.0.990) and - so far -seems OK. I've seen one occasion when I tried to navigate to a specific Britain Post Code (PO1 2LN) that the Ipaq H2210 locked up with a "Calculating..." message. I've email Route 66 support on that one.
Ther is a known (to R66 anyway) Software bug in Route 66 navigate 7 which causes the software to "stall".It happened my unit (AIRIS T920) and i got the fix today.I got the SD card reflashed with the fix and then downloaded the new Q2 2006 Navteq data onto card ....prob solved.
Route 66 are aware of this bug and do have a fix available.Contact your vendor for details.
Eirlink
eirlink
PostPosted: Fri Aug 25, 2006 10:55 pm    Post subject: Re: Can I navigate via GPS Coordinates? Reply with quote
There is a known (to R66 anyway) Software bug in Route 66 navigate 7 which causes the software to "stall".It happened my unit (AIRIS T920) and i got the fix today.I got the SD card reflashed with the fix and then downloaded the new Q2 2006 Navteq data onto card ....prob solved.
Eirlink
