daveatfcc Occasional Visitor
Posted: Sat Jun 24, 2006 8:02 pm Post subject: Belkin F8T051/Fortuna and Windows mobile 5 set up problem |
I have the Belkin F8T051 and am trying to get it to run on my XDA 11 mini s which is running Mobile Windows 5. I have a 2gb mini s card, I have tried loading the software to the phone and to the storage card, but every time I try to run it, it says that Data files are missing?
Does anyone no a fix or is it just not compatible?
Thanks |
Posted: Sat Jun 24, 2006 8:37 pm Post subject: |
Which application are you trying to load to the Mini S ? as the device is a Bluetooth device it will work with the phone - have you enabled the bluetooth connection correctly, once you have selected the serial port profile you need to go to the Com Port tab and assign a new outgoing port - Mike |
Posted: Sat Jun 24, 2006 8:54 pm Post subject: Belkin F8T051 |
Hi Mike
Sorry my fault, I should have said!
I have the Belkin GPS software which I believe is the Intellinav software.
There is not enough room on the phone memory(23mb) I am therefore trying to load it on the mini sd card (2gb) however the mapping software does not recognise the card, so when I try and load via the desktop the software is not detecting the maps or sound files? |
Posted: Sun Jun 25, 2006 3:10 am Post subject: |
I would contact the software supplier and find out for sure if the product is capable of being installed to a device running WM2005 as the operating system on the PDA/ phone - Mike |
Posted: Sun Jun 25, 2006 5:49 pm Post subject: Belkin |
I have sent various emails to the software companies, but have had no reply as yet. I will let you know how i get on!
Thanks for the advice.
Dave C |
