Pocket GPS World :: View topic - icn530 speed camera
icn530 speed camera
Goto page Previous  1, 2
TheM
PostPosted: Thu Jul 27, 2006 11:07 pm    Post subject: Re: Navman ICN530 - How do you change the alert sound for my Reply with quote
myles1 wrote:
The sound that plays when you hit a custom POI appears to be the default.wav file in the windows directory. If you take another wav file and rename it to default.wav and overwrite the file that is on the navman it makes no difference. Even if you delete the default.wav files it reappears back.
I have tried putting a new default.wav file in POI, MYPOI, SOUNDS, directories in the hope that it uses this file if it finds it there ahead of the default.
Doesn't work.
Any ideas?
I worked it out once but forgot the details -- you can specify different sounds for different POIs if you edit their INI files, however, just any WAV file will not work. I know they have to be mono, but don't remember whether 8 or 16 bit, and which sampling rate (it is important, only correct one will work). In addition to that, WAV header file must not contain any extended information, even if set to 0. You'll have to do a lot of playing around with sound editor which can save WAV files without extended information but once you find out correct parameters it does work.
Page 2 of 2
