chopper7 Occasional Visitor
Posted: Tue Jun 27, 2006 2:39 pm Post subject: Speed cameras |
TIM - downladed speed cam file etc off this site etc, printed the 5 pages out so i coud go through it carefully, it dowloaded etc but when i wnet out this mornig to try it where the speed cams are nothing happened, no alert no warning and yes i got all the boxes ticked and its active. so wot now, what have i dne wrong.
regards
keith |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Tue Jun 27, 2006 5:47 pm Post subject: |
Without actually seeing what you've done, it's hard to say, I'm afraid. _________________ Tim |
Posted: Tue Jun 27, 2006 6:00 pm Post subject: |
hi
i did exactly wot it said on the 5 page print out
downloaded from Pocet GPS Safety Camera Database
Select NAVMan
selected Consolidated by type option
extracted the files
run navam smartst desktop
connected device
clcik map poi's editor
click file open
C:\Temp\POCETGPS_UK_GATSO.ASC
click file/save to device
ticked all boxes etc visualmalert imperial 150
file name gatso
clocked ok
any thoughts
keith |
Posted: Tue Jun 27, 2006 6:08 pm Post subject: |
You have to select a .bmp file, too. Although the window appears to be filled in, it keeps the .asc extension for some reason. Give this a try, please. Select the .bmp file from the same screen as when you set the POI as active and set a distance. Set the distance to 1500' (or something like that), not 150'. _________________ Tim |
Posted: Tue Jun 27, 2006 6:10 pm Post subject: |
ok will give it a go
thanks again
k |
Posted: Tue Jun 27, 2006 6:22 pm Post subject: |
right have redone it and deleted the original download from satnav.. the only difference i can see from the instructions and what i have is that it sasy TEMP folder on sheeet and i saved it to C drive my documents. will have to wait now till i go out again with it.
regards
keith |
Posted: Tue Jun 27, 2006 6:30 pm Post subject: |
hi again
just relaised that it only lists 65 speedcameras that cant be right can it?
keith |
Posted: Tue Jun 27, 2006 6:34 pm Post subject: |
No, not enough. There are thousands, assuming you've downloaded the consolidated file, although your device will only list the first 99. _________________ Tim |
Posted: Tue Jun 27, 2006 6:36 pm Post subject: |
yes i did download the consolidated one
keith |
Posted: Tue Jun 27, 2006 7:18 pm Post subject: |
tis i again (bet u wished i hadnt bought one of these, dont u?)
right deleted speedcams off satnav deleted speedcam folders off computer and started afresh.
the file i added i started to count the listings and after 179 lost count and the cursor bar on the side hadnt hardly moved so me thinks i got the right one now, and yes on the satnav it says 1 of 99 so me thinks i got it right.
tim thank you for your continued support and help, and not losing your rag at me.
keith |
