Pocket GPS World :: View topic - Keeping Original POI Voice warnings whilst adding Speed Cam
dataprint
PostPosted: Mon Apr 10, 2006 6:25 pm    Post subject: Keeping Original POI Voice warnings whilst adding Speed Cam Reply with quote
Does anyone know if it is possible to Keep the Original POI Voice warnings whilst adding the spoken Speed Camera warnings, as adding these overwrites the default POI warnings. If so how can it be done, as I would like to use the spoken speed cam warnings but still have a couple of the original ones for other uses. Any help greatfully received.
Dave P
PostPosted: Mon Apr 10, 2006 6:45 pm    Post subject: Reply with quote
Yes, it's pefecty possible, but a little fiddly.
Basically, you need to compile your own data.chk file from indvidual samples, but the easiest way is probably to use Ray's POIExtend, which lets you have all the originals plus 15 extra ones.
Look HERE
PostPosted: Mon Apr 10, 2006 7:05 pm    Post subject: Reply with quote
If you use the existing warnings leave these in the same slots as they arrive, don't put the new voice wanings in slot 1 through 15. add the voice warnings to slot 16 through 30. This is a bit of messing around using POIExtend to extract the OGG files (or use the raw OGG files from Rays site and add them to your existing data.chk file) - Note this advise was supplied by Ray to another post - so credit where its due Mr Flanagan - MikeAlder
22.053 (15 May 24)
