bigblokey0 Occasional Visitor
Posted: Wed Mar 29, 2006 7:26 pm Post subject: speed limits are different |
when i go thru a speed camera area ie 40mph my i3 bleeps like mad saying its a 30mph zone how do i sort this cheers |
matb Frequent Visitor
Posted: Wed Mar 29, 2006 8:03 pm Post subject: |
open the relative camera ie gatso in excel spread sheet.
identify camera by its id number.
where it says @30 then change to the correct speed ie @40.
save the changes and redownload.
remember to download all the databases again as well as any other poi's you may have from one folder as it writes over what you already have in there. |
Almahadeus Frequent Visitor
Posted: Wed Mar 29, 2006 8:58 pm Post subject: |
and could you pleae let pocketgpsworld.com know about them. They may even give you a life long free membership. |
Posted: Wed Mar 29, 2006 9:45 pm Post subject: |
matb wrote: | open the relative camera ie gatso in excel spread sheet.
how do i do that |
Posted: Wed Mar 29, 2006 11:03 pm Post subject: |
for example gatso.
select the file from the camera download and open it in excel.
the spreadsheet will list all the cameras by location id number and speed setting.
what you are looking for is the camera that was causing the problem. if you dont know the number then next time you go near it you can find it by looking in your custom points and searching as each camera will be given a set distance from where you are. the one that says 0.0mls is the one you are at.
find the camera by its id number.
the speed setting is shown as @ then the speed ie @30.
change the number @30 to @40 for example then save the changes as you would normally do.
re load all your poi's if you have any and the camera databases. everything you want to put back into the i3 must be from one folder as it overwrites what was last put in. |
Posted: Wed Mar 29, 2006 11:20 pm Post subject: |
how do i do this bit have i got to plug the i3 into the pc or insert a disc or something else forgive my ignorance im new to this cheers |
Posted: Thu Mar 30, 2006 8:38 am Post subject: |
It's one of the files you downloaded from here. |
