Pocket GPS World :: View topic - TTN5 and XDA Mini-s, with BT77 GPS Receiver
liocar
PostPosted: Wed Mar 22, 2006 4:35 pm    Post subject: TTN5 and XDA Mini-s, with BT77 GPS Receiver Reply with quote
Hi, I am trying to get TT5 working on a Mini XDA-s, using a BT-77 GPS. There are many guides around to get this working on a JASJAR and I-Mate, but not XDA-Mini s. I have edited the Regiestry so it shows the GPS control panel. Does the control panel overide the settings within the Bluetooth setup.... I am totaly lost.... Any one got this working, please help.
PostPosted: Wed Mar 22, 2006 5:37 pm    Post subject: Reply with quote
Welcome to the forums. Please do not quadruple-post.
The GPS control panel is not required, it is rather a hindrance.
1. discover the BT device from your PDA Comms Manager and pair the two
2. create a new outgoing port, without encryption. Use COM0 or whatever other port is available
3. In TomTom specify "Other BT device" and the port from step 2.
liocar
PostPosted: Wed Mar 22, 2006 6:16 pm    Post subject: Reply with quote
I tried that. The problem I have is that I only get the option to set com6 or com7 within the Bluetooth manager settings, TTN5 does't give me the option for COM6 or COM7. And the Serial Port has no number at all.
tcepser
PostPosted: Thu Mar 23, 2006 1:58 pm    Post subject: Reply with quote
Go to the bluetooth settings. Click on the Devices tab (near the bottom) then click new partnership. Click on the BT GPS link, then enter 0000 as the passkey.
Then click the COM ports tab. Click new incoming port and set it as COM7, uncheck the secure connection box and click finish.
Then click new outgoing port and click next then click BT GPS, then set it as COM6, once again uncheck the secure connection box and click finish.
Load tomtom up, go to prefrences and find GPS status (or something like that) and click configure. Go to Other bluetooth device then click COM7.
That should be ok. If it doesnt work swap the com ports (so com6 is com7 and vice versa)
I really hope that helps you
Tcepser
O2 XDA Mini S
256 Mini SD Card
Tomtom Navigator 5 (Great British Map)
BT GPS Receiver
PostPosted: Thu Mar 23, 2006 2:03 pm    Post subject: Reply with quote
This step is not required. GPS connections only use the Outgoing port.
liocar
PostPosted: Thu Mar 23, 2006 3:48 pm    Post subject: Reply with quote
Like I said TTN5 does not give me com6 or com7 as an option. only 0, 3,5.
Mullet
PostPosted: Sat Mar 25, 2006 5:28 pm    Post subject: Reply with quote
liocar wrote:
TTN5 does't give me the option for COM6 or COM7. .
It never will with your WM5 device. You need to install Tomtom Mobile 5.2.
Mullet
PostPosted: Sat Mar 25, 2006 5:34 pm    Post subject: Reply with quote
Of course that should read Tomtom Navigator 5.2.
Still jet lagged.
Wish I could edit.
liocar
PostPosted: Sat Mar 25, 2006 6:25 pm    Post subject: Reply with quote
I will try that. Thanks.
liocar
PostPosted: Mon Mar 27, 2006 2:24 pm    Post subject: Reply with quote
I upgraded to 5.210, GPS DRIVER IS v1.20. It still doesn't give me Com 6 or Com 7. I have never ever had a problem with TTN2, or TTN3, but I have also never tried to use WM5. If this isn't going to work, can anyone suggest an alternate navigaion s/ware that will work on an XDA with WM5.
Mullet
PostPosted: Mon Mar 27, 2006 3:09 pm    Post subject: Reply with quote
liocar wrote:
I upgraded to 5.210, GPS DRIVER IS v1.20. It still doesn't give me Com 6 or Com 7..
This seems to be the usual case after persisting with version 5.0. If the GPS config still will not offer com 6, then the device needs to be completely turned off (possibly to empty cache). Worse case a hard reset is needed.
Your problem has been covered here http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=36100
