Pocket GPS World :: View topic - REALLY STUPID
REALLY STUPID
ronydr
PostPosted: Fri Feb 10, 2006 7:00 am    Post subject: REALLY STUPID Reply with quote
Hi everyone,
This is my 1st post, and I really need ur help.
I have bought one of those PDA/GPS car mount kit that allows me to stick the holder on the windshield.
It works well... quite solid... the problem is that now that it is stuck, is there any way to remove it if I need to???
Thanks a lot for ur help,
Rony
ride4smilesjonny
PostPosted: Fri Feb 10, 2006 10:00 am    Post subject: Reply with quote
isnt it just a suction cup thats on it ? you would release the lever you pushed down to secure it then on the edge of the suction cup will be a little tag to pull to break the seal 8O
Hi ho - Hi ho its off to Arran i go,
with my i3 and a cup of tea hi ho, hi ho
hi ho hi ho.....
www.ride4smiles.co.uk
£3500 raised in two weeks! :-)
ronydr
PostPosted: Fri Feb 10, 2006 6:05 pm    Post subject: I wish it was that easy... Reply with quote
No it is not exactly like this. The suction was to hold the device on a circular base which is "glued" to the windshield. It was easy to release the device (as u said.. question of releasing the suction). But now, I am stuck with this circular base that is glued to the winshield. I am not sure what kind of material they used... but it is very very strong...
Thanks anyways.......
bumpkin
PostPosted: Fri Feb 10, 2006 6:51 pm    Post subject: Reply with quote
As far as I know the disk shouldn't be stuck to the windscreen, you just used the sucker directly onto the glass. I seem to recall that the desk is included in the box so that you can stick that to the top of the dashboard as an alternative position to attach the sucker.
The instructions mentioned that you should be sure when installing the disk as it is extremely hard to remove. I would suggest warming it with a hairdryer before slipping some sort of blade between it and the glass. However, be prepared to some hard work getting the rest of the goo off the glass.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
bumpkin
PostPosted: Fri Feb 10, 2006 6:52 pm    Post subject: Reply with quote
Of course when I said "desk" in the first paragraph above I did mean disk Rolling Eyes
Pesky voice recognition software playing up again!
Chas
GeckoGirl
PostPosted: Fri Feb 10, 2006 8:45 pm    Post subject: Reply with quote
Try WD40 (or similar) to get off the goo once you've removed the disk. Normally works really well on things like that.
PostPosted: Fri Feb 10, 2006 9:00 pm    Post subject: Reply with quote
I find this product quite good at removing most "glue" type substances http://www.ronson.com/products/index.htm (Liquid Lighter fuel) only use a small amount on a cloth to apply it, as it can attack the dash boards of some cars. Its readily available from most newsagents etc. It is highly flamable as its petrol so don't smoke if using this idea and make sure the vehicle is well ventilated - Mike
alan_t
PostPosted: Sat Feb 11, 2006 12:22 am    Post subject: Reply with quote
just simply use abit of white spirit if the goo is stuck.
ride4smilesjonny
PostPosted: Sat Feb 11, 2006 12:46 am    Post subject: Reply with quote
In the words of Homer himself - DOH! 8O
hi ho hi ho.....
PostPosted: Mon Feb 13, 2006 12:33 pm    Post subject: Reply with quote
a cheap can of deoderant (60p from wilko's) does the trick for most sticky stuff - just don't use anti-perspirant cos ya get loadsa white bits everywhere...
mcintyre
PostPosted: Sun Feb 19, 2006 12:18 pm    Post subject: Reply with quote
You've stuck the disk to the windscreen?? Oh my. Have fun...
View user's profile Send private message Visit poster's website MSN Messenger
Ayla
PostPosted: Sun Feb 26, 2006 3:27 am    Post subject: Reply with quote
There's a product you can buy at the chemist (I think it's called Elastoff) which is used to remove the residue from elastoplast sticking plasters. They're like baby wipes and work a treat with stickers on new crockery etc. As a previous poster wrote, heat up the reside with a hair dryer, then try using one of these wipes.
22.044 (24 Apr 24)
