Pocket GPS World :: View topic - New BETA 5.01 Software- VIA's on c310??
Goto page Previous  1, 2
AndyArk
PostPosted: Thu Feb 23, 2006 11:51 am    Post subject: Reply with quote
Ericd wrote:
AndyArk,
I'm with you, have tried always to get a bitmap in there without any luck, it will be interesting to see if Garmin alter the software as the POI Loader help file still says that you can use bitmaps. Lets hope that this is a minor hiccup with the Beta version. I am also going to E mail Garmin about this, the more the merrier.
Ericd
Just had the following reply from Garmin :-
I have just tested on a GPS in the office with the latest software, and it
worked you will have to make the images are 22h & 22w and they will load
into the GPS.
I'll give it a try tonight, but I bet he was using v4.8 - although I did say that it was 5.01 that was causing the problem.
AndyArk
PostPosted: Thu Feb 23, 2006 12:00 pm    Post subject: Reply with quote
I've just checked & the Pocket GPS speedcam BMP's are 22x22 & these definately don't work.
Another email to Garmin I guess Sad
gcb
PostPosted: Thu Feb 23, 2006 4:29 pm    Post subject: Reply with quote
Ask them
For 4.80 What size and how many colours.
For 5.10 (beta) What size and how many colours.
gcb
PostPosted: Thu Feb 23, 2006 5:42 pm    Post subject: Reply with quote
Waypoints.
I have 4.80.
On my C310. Whilst navigating, with reception, If I enter a second destination without cancelling the first I do not get an option to include this second destination as a way point. I assume this is a 5.01 feature.
Saving favourite location from map view. On the I3 just press wheel and hold. It there a similar quick save position on the C3xx I havent figured yet? I've tried brows map then touch somewhere , if that somewhere is close to a road or feature I sometimes get a new location. If I touch a place on a road , or an area shaded as industrial park I get a location to navigate to, but no way of getting the location to my favourites/ saving it for future use. ??
Marc_L400
PostPosted: Thu Feb 23, 2006 10:19 pm    Post subject: Reply with quote
Garmin have released Beta version 5.02 correcting so,e of the bugs reported:
    Changes made from version 5.01 BETA to 5.02 BETA:
    Corrected a bug that was causing custom POI icons to not display properly.
    Corrected a bug which was causing some routes to be calculated improperly.
    Corrected a bug where telling the unit to 'Detour' would lose the via point if one was set.
    Added ability to use 'HOME' as a via point when selected from the 'My Locations' page.
    Corrected a bug where some routes would give less voice guidance then they should.
http://www.garmin.com/support/download_details.jsp?id=1279
Havnt tried it as yet but will do very shortly will report on the icon status,
Marc
Marc_L400
PostPosted: Thu Feb 23, 2006 10:30 pm    Post subject: Reply with quote
Update as far as i can see the icons are all back on for the poi's on the camera db so looks like thats one thing sorted and possibly the incorrect routing also,hope it helps
Marc
AndyArk
PostPosted: Fri Feb 24, 2006 9:33 am    Post subject: Reply with quote
Marc
I guess when Garmin told me it works with the latest firmware they were using this! - Sounds like its sorts it out.
Ericd
PostPosted: Fri Feb 24, 2006 2:09 pm    Post subject: Reply with quote
Good job we have this Forum, just had a look and saw the info regarding Beta 5.02. Downloaded, Installed and voila! all seems corrected. I am still awaiting a reply from Garmin who I E mailed on 22.02. Well done Andy Ark and Marc4
Ericd
Ericd
PostPosted: Fri Feb 24, 2006 7:50 pm    Post subject: Reply with quote
Further to the above, have just received the following from Garmin.
Hello,
This is simply a fault into he 5.01BETA software. We do say on the web page that this software is to be used at your own risk and is not supported by us simply due to its status. I would recommend you reinstall the 4.80 software until the final version of the 5.* software is released.
Tom Bird
Product Support / Cartography
Garmin (Europe) Ltd
It seems that not everybody at Garmin is aware of the latest fix
regards,
Ericd
Page 2 of 2
22.052 (08 May 24)
