chivvy Occasional Visitor
Posted: Wed Mar 22, 2006 6:26 pm Post subject: Avoiding a point on route |
Is it possible to avoid a point on a route? Using the recalculate route avoiding section seems to only let you avoid a whole road so if you were travelling along the A303, for example, it would avoid th ewhole A303 whereas you might just want to avoid one small part of due to an accident/roadworks etc. You could use the roadblock bit but you have to know exactly how far away you are from the blockage (ie 3miles).
Is there another way?
Chivvy |
lupos0_1 Lifetime Member
Posted: Wed Mar 22, 2006 6:55 pm Post subject: |
Hi there and welcome !!!
I don't believe there is that option. _________________ -------------------------------------------------------
Nokia N95
McGuider V7
Latest Maps
(Internal GPS) |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Wed Mar 22, 2006 10:17 pm Post subject: |
Tap on Screen
Find Alternative.
Travel via.
go to next page
Point on map. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Posted: Thu Mar 23, 2006 9:47 am Post subject: |
Thanks Lost_Property, but doesn't that imply that I already know an alternative route? I may know where a problem is, but not necessarily know the best way around.
However, I shall keep your suggestion handy for those instances when I do!!
Chivvy |
oddsock Pocket GPS Verifier
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Thu Mar 23, 2006 10:52 am Post subject: |
What version of TTN are you useing?? In TTN3 you can draw out "Avoid area" boxes which can be as large or small (down to a single carriagway on a motor way)as you want .( This feature may have beeen removed from TTN5 in the name of progress ) This should let you filter out sections of road but you would have to guess as to the actual distance you would want to avoid..Thats as good as it gets I'm afraid
Dave _________________ TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest |
Posted: Thu Mar 23, 2006 3:02 pm Post subject: |
Thanks Oddsock that's exactly the sort of thing I wanted but I, in my infinite wisdom, am using the 'far superior' TTN5.
Live & Learn!
Chivvy |
Posted: Thu Mar 23, 2006 5:06 pm Post subject: |
Quote: | but you have to know exactly how far away you are from the blockage |
This applies to anything you try.
Eh, but hopefully evryone in front will have a Sat Nav and be re-routed and you'll end up with an empty road. :P _________________ Formerly known as Lost_Property
