Pocket GPS World :: View topic - garmin 76 and ipaq 3970
donny
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: garmin 76 and ipaq 3970 Reply with quote
I am having problems getting at connection between the two on a seriell cable (with a gendre changer). The Garmin is set to NMEA 4800 and the tomtom GPS the same -but no connection. I have ROM 2.10. Cant get the GPS on the route planner either. What is the problem. Greateful for any input.
Pc-Mobile
It is almost definitely one of the 2:
1. You do not have a "proper" null modem adapter, which is need between the 2 serial cables. A mere gender changer will not do.
2. You have a keyborad instlled? If so you have to disable/remove it.
Pc-Mobile
http://pc-mobile.net/gps.htm
donny
Thank you for your prompt answere.
I am on my way to buy a real null modem adapter, and hope it will help.
Donny
donny
That was it..
Thanks again. Donny
Nightowl
I've just connected my Garmin to my ipaq.
I used the existing leads with a serial connector.
A gender bender will not work. You have to make sure that there is a swapping of connectors.
essentially pin 5 on both is earth
pin 2 has to cross- over to pin 3 on the other serial connector and pin 3 to pin two.
As I understand it, if you don't then the transmit and the receive wires conflict.... so no connection.
You can buy ready made cables that go from the ipaq to the gps.
I might do that yet... I'm sick of all the wires that you have to have laying about.
hope it helps.
DavidW
As PC-Mobile correctly said, you need a "null modem", not just a gender changer.
So far as ready made cables go, he's one of the biggest vendors and most seem delighted with his products.
22.054 (22 May 24)
