Pocket GPS World :: View topic - Renault Scenic III dashboard Tom-Tom giving incorrect positi
Post new topic   This topic is locked: you cannot edit posts or make replies.    Pocket GPS World Forum Index -> Factory-Fit and In-Dash SatNav Systems
lundavra
PostPosted: Sun Jul 01, 2012 1:58 pm    Post subject: Renault Scenic III dashboard Tom-Tom giving incorrect positi Reply with quote
I ran an update on the card out of the Tom-Tom Sat Nav yesterday.
I was out in the car later in the day and did not notice anything wrong.
I set out on a longer journey today and soon noticed that the Sat Nav position was about a couple of hundred yards out.
I tried stopping, turning off the Sat Nav, taking the card out then putting back in but still the same.
I have driven about 140 miles but the position is still wrong, I checked against another GPS and the Latitude is the same but there is about nine degrees difference between the two Longitude readings.
When I got to my destination I took the memory card inside and did an update again.
Tried it back in the car but still showing the wrong position.
Earlier the year I had a similar problem though it was showing several miles error. That time it sorted itself out after half an hour or so.
Anyone have any ideas?
MB
AliOnHols
PostPosted: Sun Jul 01, 2012 3:08 pm    Post subject: Reply with quote
Have you seen the other topic about this same issue running in the general TomTom forum? Members are reporting that a Time Sync can help to cure this.
Garmin Nuvi 2599
SatMap Active 10 & 20.
lundavra
PostPosted: Sun Jul 01, 2012 3:14 pm    Post subject: Reply with quote
Thanks, I will check that area and give that a try.
MB
Anita
PostPosted: Sun Jul 01, 2012 4:15 pm    Post subject: Reply with quote
Please continue any discussion in this thread to avoid posts on the same problem being split between different threads.
I'll lock this one.
Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21
Post new topic   This topic is locked: you cannot edit posts or make replies.    Pocket GPS World Forum Index -> Factory-Fit and In-Dash SatNav Systems All times are GMT + 1 Hour
22.052 (08 May 24)
