hammerhead Occasional Visitor
Posted: Mon Feb 04, 2008 8:18 pm Post subject: uk postal codes need help |
hi.
i have got a tomtom go 300.
have installed new softwere v7.162.
and new map uk and ie v 6.75.
all on tomtom home 2.2.
so i can map shere amd keep up to date.
but do i need to update my post code ?
i tryed it out at work today but the post code don't work as before
ie.
nav to
address
postcode
i put my post code in and it displays it at the top as before but the back button at the bottom right corner don't chang to done no more. i have to select it from the list under the top line.
is this right know or do i need an postcode update
any help welcome |
Oldboy Pocket GPS Moderator
Posted: Mon Feb 04, 2008 9:06 pm Post subject: Re: uk postal codes need help |
hammerhead wrote: | i have to select it from the list under the top line. | That is the default method. _________________ Richard
Posted: Mon Feb 04, 2008 10:05 pm Post subject: Re: uk postal codes need help |
Oldboy wrote: | hammerhead wrote: | i have to select it from the list under the top line. | That is the default method. |
but before i updated it i did't need to select it before. just touch the done button. whitch is the back button now antill you select it from the list.
ok thanks
it will take so getting use to. |
GerryC Pocket GPS Moderator
Posted: Tue Feb 05, 2008 12:02 pm Post subject: Re: uk postal codes need help |
hammerhead wrote: | but before i updated it i did't need to select it before. just touch the done button. whitch is the back button now antill you select it from the list. |
Have just had a look with an old version of firmware and you are correct, it did say "Done" in the corner where it says "Back" now. This must have changed when you updated the firmware so now you need to tap the postcode at the top of the screen to select it - just like most other screens. _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
Posted: Tue Feb 05, 2008 10:58 pm Post subject: Re: uk postal codes need help |
GerryC wrote: | hammerhead wrote: | but before i updated it i did't need to select it before. just touch the done button. whitch is the back button now antill you select it from the list. |
Have just had a look with an old version of firmware and you are correct, it did say "Done" in the corner where it says "Back" now. This must have changed when you updated the firmware so now you need to tap the postcode at the top of the screen to select it - just like most other screens. |
thanks for looking
but i used it today and on some of the post codes did't show up correctly
so i had to put in the address instead.
i will give it a week to try it out.
but i may put the old one back in.
at least with the old one it alway talk you to the right address, there was no need to put the full adress in. |
Posted: Mon Feb 18, 2008 8:54 pm Post subject: |
HAS ANY ONE GOT MORE IN FO ON POSTCODES?
STILL NOT WORKING RIGHT |
Andy_P Pocket GPS Moderator
Posted: Mon Feb 18, 2008 9:10 pm Post subject: |
Don't know what you meant by "not working right"....
Do you mean the display isn't how you like it? As described above, it simply doesn't look that way any more.
Or do you mean that some specific postcodes are wrong?
Or do you mean that you no longer have full seven digit postcode search at all?
Different problems, different solutions (if any). |
Posted: Fri Feb 22, 2008 10:07 pm Post subject: Re: uk postal codes need help |
hammerhead wrote: | GerryC wrote: | hammerhead wrote: | but before i updated it i did't need to select it before. just touch the done button. whitch is the back button now antill you select it from the list. |
thanks for looking
i still prefer this old setup for post code |
Posted: Fri Feb 22, 2008 10:36 pm Post subject: Re: uk postal codes need help |
hammerhead wrote: | i still prefer this old setup for post code |
Your choice. Either use the old software and have postcodes input the way you are used to; or use the new software and have mapshare but use the current method of input.
You could also try the updated postcodes at http://62.250.16.51/customers/Nav/PostcodeWE1GB.zip. They may be more up to date than your current ones (Remember to back up first). _________________ Gerry
TomTom730T
