Pocket GPS World :: View topic - out of my depth- help needed in laymans terms
tubbs
PostPosted: Fri Nov 18, 2005 12:41 am    Post subject: out of my depth- help needed in laymans terms Reply with quote
Rolling Eyes i started out with hp navigator 4 with ipaq 1710.
this was upgraded to navigator 5. then, to rid myself of cables i upgraded to ipaq 2110 and syson bluetooth gps plus.
i have tried numerous ways to load tomtom but have not managed to successfully do this.
if anyone could give me advice in simple terms, i would be very grateful.
lbendlin
PostPosted: Fri Nov 18, 2005 1:02 am    Post subject: Reply with quote
what's the current status - did you manage to install TTN on the new PDA yet?
Lutz
TomTom/TeleAtlas NAVTEQ
tubbs
PostPosted: Fri Nov 18, 2005 1:07 am    Post subject: status Reply with quote
at the moment, the position is that i have installed the maps to the sd card, but on the pda there is no shortcut available. the last attempt loaded the tomtom, but it could not find any maps, so i deleted the program and started again.
tubbs
PostPosted: Fri Nov 18, 2005 1:18 am    Post subject: a bit more information Reply with quote
just thought, i am trying to do this with a card reader, not by synchronising computer. i wondered if this made a difference.
Pocketgps
PostPosted: Fri Nov 18, 2005 2:07 am    Post subject: Reply with quote
Some card readers will load the data to the card that can be seen on your main pc ok, but cannot be seen on the PDA. Yes, try ActiveSync, takes for ages, and sometimes looks like its restarting when sending the map data to the card on the PDA, but its not, just wait and it should complete ok. Could be between 30-50 minutes.
lbendlin
PostPosted: Fri Nov 18, 2005 2:17 am    Post subject: Reply with quote
you should never install maps through ActiveSync. The TomTom installer gives you the option to install to storage card reader, and you should take that offer.
The application however can be installed through ActiveSync, and this should not take very long.
Lutz
tubbs
PostPosted: Fri Nov 18, 2005 2:34 am    Post subject: progress report Reply with quote
i have just tried installing via sync. but the only programs i find in add/remove programs are great britain map and zip. the application does not appear
lbendlin
PostPosted: Fri Nov 18, 2005 2:53 am    Post subject: Reply with quote
Let me rephrase. The application can be installed with the TomTom installer when the Pocket PC is connected to the PC. So ActiveSync is not (directly) involved (but a connection should exist).
Lutz
tubbs
PostPosted: Fri Nov 18, 2005 3:00 am    Post subject: i apologise for my ignorance Reply with quote
this might seem a silly question, but how do i get the application to load on the pda? i have just run setup again but it just wants to install maps again.
lbendlin
PostPosted: Fri Nov 18, 2005 5:25 am    Post subject: Reply with quote
You need to use the first CD to install the application. All the other CDs only allow you to install maps.
Lutz
tubbs
PostPosted: Sat Nov 19, 2005 1:06 am    Post subject: still not happening! Reply with quote
i have been using cd1, but it has not loaded the application
tubbs
PostPosted: Sat Nov 19, 2005 2:10 am    Post subject: i just dont know Reply with quote
the only way i have been able to get the application on my pda, is to use the navigator 4 sd card that i originally got. this is now not valid to activate as i upgraded. have tried to use cd1 of navigator 5 from this position but still get nowhere. i am sorry if you feel i am a numbskull!!, but i haven't got a clue what to do next.
Oldboy
PostPosted: Sat Nov 19, 2005 9:40 am    Post subject: Re: still not happening! Reply with quote
In the complete TTN5 package you should have 7 CD's. CD1 - 6 contains the maps. The 7th CD contains the Application.
They are numbered 1-6 because the same CD's are used by the GO, but it doesn't need the application CD.
tubbs
PostPosted: Mon Nov 21, 2005 2:20 am    Post subject: THANKS TO ALL Reply with quote
cheers for all your help, everything is hunky dory now and working well.
as i said at the beginning, i am not a techi, but not even to use the right disc, what an idiot!!!!
davast
PostPosted: Mon Nov 21, 2005 2:24 pm    Post subject: Reply with quote
Can you tell me which CD the UK maps are on as I cannot find them?
22.053 (15 May 24)
