Pocket GPS World :: View topic - HELP - TomTom 5/HP4150/Fortuna ClipOn Bluetooth GPS
HOOFLUNGDUNG
PostPosted: Tue Nov 08, 2005 4:00 pm    Post subject: HELP - TomTom 5/HP4150/Fortuna ClipOn Bluetooth GPS Reply with quote
I've loaded TT5 onto my HP4150 but when trying to set up connection with the Fortuna ClipOn it doesn't seem to be able to see it. Iknow the Clip On is working OK with the HP as I use this setup with Fugawi and Mapopolis but for some reason TT5 can't find the ClipOn.
Any suggestions?
StevenGourlay
PostPosted: Tue Nov 08, 2005 4:09 pm    Post subject: Reply with quote
Have a look at
http://www.totalpda.co.uk/forum/showthread.php?t=3330
If you are having problems with tomtom navigator 5 connecting to your Bluetooth GPS then follow the guide below:
1) Make sure Bluetooth is enabled on your PDA and the GPS is turned on.
2) On the PDA go through the bluetooth manager and setup the GPS device, and then add to your paired devices.
Follow the guide CLICK ME
Click on tomtom navigator
Tap on the screen and select Change Preferences (big spanner)
tap the black triangle until it says Preferences 4 of 6
Select Configure
This is the stupid part Select "other cable NMEA GPS" yeah thats right CABLED
GPS Baud Rate 4800 and select DONE
Select the correct bluetooth port, if you cannot see the number tap and hold and then you will see what number.
You will notice a small orange and black circle at the top right this will start to spin if you are connected to the GPS if it does not spin then soft reset the PDA and try again.
Edited due to customer feedback
if it still fails and you are going from 3-5 then try below.
Process:
- uninstall Nav 5
- Reinstall Nav 3
- Install 3.07 patch (if not already installed as above)
- Remove TomTom Navigator ONLY from the remove programs list.
- Reinstall Nav 5
- Run Navigator, go to GPS setup and, for me at least, use tomtom bluetooth selection.
__________________
Regards
Steven Gourlay
Bike Pics! Bike Chat! Visit-Ullapool
