Pocket GPS World :: View topic - Help needed on Splash Screen
Jonhead
PostPosted: Sun Oct 30, 2005 11:42 pm    Post subject: Help needed on Splash Screen Reply with quote
Hello
I've finally taken the plunge and brought a Go 300 and see everyone displaying the wicked Splash screens, now i got one i wanted to use followed all the instructions and it never comes up, I have called it splash.bmp and just splash and droped it just into the SD Card, all i get in the tom tom hand or its just goes straight to the map, i have a 300 running 5.201, i got the screen from a cd and even tried one that looked the other way round, still just goes straight to the main map screen.
Hope someone can help me!
PostPosted: Sun Oct 30, 2005 11:55 pm    Post subject: Reply with quote
First try downloading one from here : http://www.gomo-web.de/
as they download in the right format and orientation.
Ensure that if you are using Windows that Explorer is not hiding file extensions (every file you see should have a three letter extension) then rename the downloaded file splash.bmp. Put it in the root (ie not inside any folder) and it should work. One or two people have said that they needed to do a paperclip re-boot for it to work.
Once that is working, try again with your file. If that doesn't work you need to check:
1) is it really a bmp file? (not another format just renamed to .bmp)
2) 24 bit
3) Size and orientation
All of these can be checked by looking at file properties in any reasonable paint program.
Check all that, and post back if still having problems
PostPosted: Mon Oct 31, 2005 9:13 am    Post subject: Reply with quote
And double check the file name, if you have file extensions hidden (default) on your PC then you may find it is called splash.bmp.bmp which won't work.
Jonhead
PostPosted: Tue Nov 01, 2005 1:39 pm    Post subject: Reply with quote
Thanks very much, seems to work fine now!
Must have been doing something drasticly wrong, cant see what though!
Anyway works now so i'm happy!
Must have been of the dodgy cd i ordered!
Thanks again
Jon
surfgeek
PostPosted: Wed Nov 23, 2005 10:04 pm    Post subject: Splash screen now working Reply with quote
I had a problem getting my custom splash to show, but heres why.. saved as 16bit instead of 24 bit.
Now looking good. Laughing
PostPosted: Thu Nov 24, 2005 4:39 pm    Post subject: Reply with quote
Point 2) above Wink
