SpeedCam Frequent Visitor
Joined: Mar 18, 2004 Posts: 753 Location: Biggleswade, BEDS
Posted: Sun Oct 23, 2005 9:46 pm Post subject: New GPS Support In Windows Mobile 2005 |
Having received my new o2 Exec PDA last week I've now started to investigate some of the new functionallity ie the new Windows Mobile 2005 GPS Support. Supposidly this provides the abillity to share a single GPS stream to many different applications.
Has anyone else had a play with this, and have they managed to get TT V5 to recognise the virtual COM port. TT happily sees the real port but fails to communicate on the virtual port.
I'm aware that TT do not support WM 2005 yet, I'm still waiting for them to fix WM 2003 .... just keeping them on their toes.... |
alix776 Pocket GPS Moderator
Posted: Sun Oct 23, 2005 10:03 pm Post subject: |
theyve hidden the control pannel you need a reg editor to access it or pocket bt tools to lock the serial port other wise after 3 softreset it will loose te pairing and com port _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sun Oct 23, 2005 11:50 pm Post subject: |
Not sure if I've understood correctly, I've already modified the registry to unhide the GPS tool, is there another registry setting needed? |
bigswede Occasional Visitor
Joined: Dec 02, 2004 Posts: 16 Location: Karlstad, Sweden
Posted: Mon Oct 24, 2005 4:01 pm Post subject: |
...well I'm running a Dell x51v and it has WM5.
Did not need to do any reg-hack to reveal the GPS tool. It was there from the begining.
At first I ran TT using the WM5 GPS-sharing and it worked. There were some issues though.
I first needed to start TT and then change to GPSViewer and toggle the open and close button, return to TT and voila it worked.
It seemed that TT could not open the com-port by itself.
...then "jonburg" informed me http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=156699#156699 that if I did NOT use the GPS-sharing it would work better...and it did, THANX "jonburg".
Now I run TT against com7 directly and it's working great.
/BigSwede _________________ _________________________
Dell Axim x51v
Sandisk ULTA II 1Gb SD
Holux GPSlim 236 |
