Newsletter
Pocket GPS World :: View topic - How do I put new maps onto SD card
bluenose66
PostPosted: Tue Oct 18, 2005 9:09 pm    Post subject: How do I put new maps onto SD card Reply with quote
Hi finally got my NZ maps for the PIN 570 and should be with me by Thursday (fingers crossed), I do not have a card reader, just a PC. Is this a problem?, if not could somebody explain how I get the maps onto a new SD card.
Thanks in advance...........
intertoto
PostPosted: Wed Oct 19, 2005 12:33 pm    Post subject: Reply with quote
Hi Bluenose66,
Without a Card reader/writer you may find transfering maps quite time consuming. However it is possible.
You will need to install ActiveSync on to your PC (if you haven't done so already) and connect your PiN 570 with new SD card inserted.
Load up the Navman software on your PC (this again may need to be installed from the CD's in the PiN package if you haven't done so already). Once this has loaded you should see a map of the world. Click on the map you wish to install.
The software should ask you to insert CD's and enter the activation codes supplied with your new maps.
On the right of the Navman Map installer window you should see a number of locations to install the maps. Make sure you select the SD card within the PiN device. As mentioned above this will take a while to transfer.
If you are still struggling, Navman have a dedicated technical support line and I'm sure they will be able to help on 01293 780500
You could look at investing in a Card reader/writer especially if you are looking to move maps in the future.
www.globalpositioningsystems.co.uk/p3411
Jonathan Bowes
Product Manager
YooNoo Ltd
bluenose66
PostPosted: Wed Oct 19, 2005 10:39 pm    Post subject: Reply with quote
Intertoto,
Cheers mate - that seems quite easy to, appreciate it.
intertoto
PostPosted: Fri Oct 21, 2005 12:36 pm    Post subject: Reply with quote
No Problems Bluenose66,
Let us know how you get on
Jonathan Bowes
Product Manager
YooNoo Ltd
20.054 (25 May 22)
