PAUL-R-S Occasional Visitor
Posted: Fri Sep 16, 2005 8:12 pm Post subject: How to make my own POI |
for instance im a mobile engineer and use plumb center alot. if i know all there branch address can i set up my own POI ?
or even better can someone who knows whats there doing make it up. pleaseeeeeeeeeeeeeee |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Fri Sep 16, 2005 8:18 pm Post subject: |
Do you have full postcodes for all of the addresses, and do you own MS Autoroute? _________________ Tim |
Posted: Fri Sep 16, 2005 8:24 pm Post subject: |
not got autoroute but do have full address's |
Oldboy Pocket GPS Moderator
Posted: Fri Sep 16, 2005 10:07 pm Post subject: |
Give me a few days and I'll let you know when I've finished. _________________ Richard
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Fri Sep 16, 2005 11:00 pm Post subject: Re: How to make my own POI |
PAUL-R-S wrote: | for instance im a mobile engineer and use plumb center alot. if i know all there branch address can i set up my own POI ?
I have a Plum Center poi, have a look, the files are in both .asc & .ov2 format with icon and sound file, but not sure how good it is, let me know if its ok.
Download HERE |
Posted: Sat Sep 17, 2005 11:41 am Post subject: |
Great work, I can confirm the ones I know of in and around the Fylde are are in the correct place, Oldboy do you mind explaining how to do this using AutoRoute - I've got as far as importing the Excel data as pushpins but stopped at that point - Cheers
Mike |
Posted: Sat Sep 17, 2005 12:44 pm Post subject: |
mikealder wrote: | Great work, I can confirm the ones I know of in and around the Fylde are are in the correct place, Oldboy do you mind explaining how to do this using AutoRoute - I've got as far as importing the Excel data as pushpins but stopped at that point - Cheers
Mike |
You save the map, normally as an .axe file.
Using Oldies POIConverter program - http://rjdavies.users.btopenworld.com/html/poiconverter.html open the .axe file and then save as TomTom file.
Simple, and it works.
Next create your custom .bmp file. _________________ Richard
Posted: Sat Sep 17, 2005 12:49 pm Post subject: |
Many thanks - will try that later on when I have finished re-building the TT menu structure with the online tool set, decided to mess around with it big style last night - best improvement to date is loading up another voice complete with voice matched data.chk file so its a common voice for prompts and speed cams - just need to finish the menu then I might be fully happy with TT5 - cheers Mike |
