Pocket GPS World :: View topic - TT5 (IPAQ2210) - map problem...?
chalkstorm
PostPosted: Tue Aug 30, 2005 9:13 pm    Post subject: TT5 (IPAQ2210) - map problem...? Reply with quote
I've used TT3 for some time - including the European maps - with no problems. Bought the TT5 upgrade - and installed the Great Britain Plus maps - and been using them without issue. I'm off to France next week so tried to install the France maps. I have tried various installation routes (tomtom setup straight onto the SD card, tomtom set up to PC folder - then drag them onto the SD card) - but whenver I go into navigator to switch maps, the only option is the great britain one.
Can anyone help? I've searched the forums and can't find any answers...?
Thanks in advance
Simon
PostPosted: Tue Aug 30, 2005 9:20 pm    Post subject: Reply with quote
You can open v3 maps with 5.000 by setting the last line of the PNA file to 562. But 5.100 will no longer allow that.
chalkstorm
PostPosted: Tue Aug 30, 2005 9:30 pm    Post subject: Reply with quote
Hi Lutz
Thanks for your quick reply...
Why won't it open v5 maps - when I am using TT5....? The France maps are sitting pretty on the SD card - but navigator just can't see them to let me switch to them? I have deleted all TT3 stuff now...
Thanks again
Si
PostPosted: Tue Aug 30, 2005 10:20 pm    Post subject: Reply with quote
you are right, it should open v5 maps just fine. Try to re-install the map from CD directly to the storage card using a card reader on the PC.
SteveW
PostPosted: Tue Aug 30, 2005 11:18 pm    Post subject: Reply with quote
I had a similar problem with my daughter's 1710. The SD card would be ok on my PDA, but would not read in hers. Turned out to be a speed issue as it was an old card, and the only solution was to buy a new higher speed SD card.
Steve
chalkstorm
PostPosted: Tue Aug 30, 2005 11:51 pm    Post subject: Reply with quote
Hi all
Just a quick update. Tried a 256mb card (not the Kingston 512mb I'd been using). Just installed the French maps on it - put it in the IPAQ - started Navigator - and the message came up - no maps found...? It seems it can only find the Great Britain maps....
I ruled out the card (both of them) and the Ipaq. Is it some setting on TT5....?
Thanks again
Si
CalumLawson
PostPosted: Wed Aug 31, 2005 10:30 am    Post subject: Reply with quote
Simon
Very strange, I'm running the exact same set-up as you iPAQ 2210, UK plus map and I installed the France map with no problems at all. Do you get the directory created on your Storage card ok, should be "France-Map" assuming it isn't the plus map your installing?
However in general use (ie not just after installation), I have once or twice seen this message and a soft reset was enough to clear it. Have you tried that?
HTH
Calum
chalkstorm
PostPosted: Sat Sep 03, 2005 10:43 am    Post subject: Reply with quote
Ahhh.... got an embarassing confession to make. I have many versions of TT. After buying a card reader and trying many installations of TT and the maps, I realised I was using TT3 maps with the latest version of Navigator! Fool so I am. Now got the lot working once I worked out which were the latest versions of the CDs (which aren't marked very clearly anyway!)
Thanks all for you help...
Si
