Pocket GPS World :: View topic - Adding Maps to memory card - please help
linknet
PostPosted: Fri Jul 22, 2005 8:17 pm    Post subject: Reply with quote
The times on this forum seem odd. This should be the second post.
I haven't a UK MRE map only a Great Britain and Ireland map?
Regards
Roger
Pocketgps
PostPosted: Fri Jul 22, 2005 10:22 pm    Post subject: Reply with quote
If you have used Card Reader to transfer the UK map to the card then that may be the problem, try copying it from your old card to a folder on your main pc, then place the new card into your PDA and copy it ot it using ActiveSync, I know it takes for ever that way but it usually works.
Before you do that have you selected the map from the menu when running Medion Navigator, you should see:
One destination
Several destinations
Show Map
Select Map - this is the button you need to use - you can only select one map at a time
Settings
Help
Quit
Rebecca
PostPosted: Fri Jul 22, 2005 11:09 pm    Post subject: Adding Maps to memory card - please help Reply with quote
We have 4.2 running on a pocket-pc (Aldi special)
Bought a 512 memory card to store UK and France maps in one place. We have successfully copied France onto the card via Active Sync. Seems to be fine. We've also tried to copy the standard UK MRE file onto the card.
Using File explorer the UK file seems to be on the card, but the navigation software can't seem to find it.
Any ideas how to resolve this?
Thanks in advance,
Rebecca
Rebecca
PostPosted: Fri Jul 22, 2005 11:09 pm    Post subject: Reply with quote
Thanks, will try copying it in the way you suggest from the original card. It's weird that it won't work given that I've copied it in the exact same way as the successful France folder! Rolling Eyes
It's definitely not listed as a choice when you select country. Only France and Monaco appear.
