Pocket GPS World :: View topic - How to get Ozi map to PDA
GrahameS
PostPosted: Mon Jun 20, 2005 10:09 pm    Post subject: How to get Ozi map to PDA Reply with quote
I have iPAQ 4700 with OE CE beta 1.11.4
On PC with OE 3.95.4i I made and calibrated map and sent with Img20zf ver. 3.00 to PDA but I can't find it.
The pocket PC shared/synced file on the PC has the map in ****.map (4KB) , ****.ozfx3 (1580KB) and ****-ozf.map formats.
Where/how do I find the map?
barryd
PostPosted: Tue Jun 21, 2005 8:26 pm    Post subject: Reply with quote
Hi there
The .ozfx3 file is the converted graphic and the -ozf.map is the map file that references it. These two need to be on the Pocket PC.
The .map file is the original map file that references your original graphic in .tif or .bmp or whatever. These two aren't needed on the Pocket PC.
In Img2Ozf, look at the Configuration tab and it will tell you where it put the files on the Pocket PC. You can then check that they are in those folders on the Pocket PC using Windows Explorer, for example. If not, simply copy them across.
You also need to configure OziExplorerCE to know where to look for map and image files. On my version (1.11.6h BETA) you set it up using these menu options:
File - Configuration - Map & Data Files (set this to the -ozf.map files folder)
File - Configuration - Map Image Files (set this to the .ozfx3 files folder)
You should then be able to do File - Open Map File and see a list of all your .map files on the Pocket PC.
Barry Davies
22.053 (15 May 24)
