Pocket GPS World :: View topic - GM-270 Low Power or WAAS
Don Schmitt
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: GM-270 Low Power or WAAS Reply with quote
Hi all,
Has anyone successfully enabled trickle mode or WAAS/EGNOS on their GM-270?
I've tried the "GPS Viewer" utility, but I've experienced what other posts indicated: It doesn't seem to do anything. I tried the GPSTweak utility, but it doesn't seem to work properly. I would like to try "CE Monitor" or "WinFast navigator", but I'm unable to find current download locations for either of them (the existing links are broken)? Are there other utilities available that might work?
Thanks!
<a href= "mailto:donsc@blackfishsoftware.com">Don Schmitt</a>
Blackfish Software
<a target="_blank" href= "http://www.blackfishsoftware.com">Pin Distance</a> - Know your distance to the green
david77
PostPosted: Tue Dec 02, 2003 12:28 am    Post subject: Reply with quote
I am not sure this is the answer you were looking for but...
I was able to active both trickle mode or WAAS/EGNOS but only after the start GPS. Hope this help you
22.051 (01 May 24)
