Pocket GPS World :: View topic - smartphone help needed
dannygr27
PostPosted: Sat Feb 26, 2005 12:12 pm    Post subject: smartphone help needed Reply with quote
hi ive just got the tomtom smartphone mobile on my nokia 6600 and i want to put the speed camera software on but dont know what software to use could someone please help !!!!
PostPosted: Sat Feb 26, 2005 12:52 pm    Post subject: Reply with quote
You don't need any additional software, you just need to copy the Safety Camera database files (.ov2 and .bmp) from our download into the Map Folder (i.e. Great_Britain) on your 6600's storage card.
The simplest method is by using a card reader connected to your PC. The other way is using Nokia's PC Sync Software.
dannygr27
PostPosted: Mon Feb 28, 2005 7:25 pm    Post subject: Reply with quote
i copied all the files as stated but it wont seem to work Confused
PostPosted: Mon Feb 28, 2005 8:07 pm    Post subject: Reply with quote
Have you enabled the POI's for 'warn when near'?
dannygr27
PostPosted: Mon Feb 28, 2005 9:57 pm    Post subject: Reply with quote
theres nothing in the poi that says anything to do with the speed camera
PostPosted: Tue Mar 01, 2005 8:31 am    Post subject: Reply with quote
Which would suggest you have made a mistake when copying the files somewhere along the line.
You should have a .ov2 and a .bmp file for each camera category located in your map folder (i.e. the Great_Britain_Map folder). the .ov2 file contains the location data e.g. pocketgps_uk_gatso.ov2 and the corresponding .bmp file is the icon for that database.
Double check that the correct files exist in the map folder (you should extract these from the downloaded .zip file) then power off and on the phone and check to see that they are available in the POI Preferences section.
dannygr27
PostPosted: Tue Mar 01, 2005 11:22 pm    Post subject: Reply with quote
this is what ive done you might see what im doing wrong
downloaded the zip file opened it
copied all the ov2 and bmp files to the great_britain file on my phone i then opened speed zone then opened geso folder and copied all the ov2 and bmp files i then opened the mobile folder and copied all the ov2 and bmp files turned off phone and got nothing Laughing Out Loud
PostPosted: Wed Mar 02, 2005 8:39 am    Post subject: Reply with quote
Well for starters you're copying too many files. The speed zoned files are not intended for TT Mobile (nor GO, Palm or HP Versions).
Ignore the 'speed zoned' folder and its contents. You'll need to remove all the others that you have previously copied over then as an experiment just copy the pocketgps_uk_gatso.ov2 and pocketgps_uk_gatso.bmp files from the root of the archive into your map folder.
dannygr27
PostPosted: Wed Mar 02, 2005 11:19 pm    Post subject: Reply with quote
hi ya
yeap done that but it still didnt work i also deleted it and tried it with just the mobile files but that didnt work to
bluetba
PostPosted: Mon Mar 14, 2005 5:08 pm    Post subject: Reply with quote
I hope you did get it sorted in the end, but just in case...
I had the same problem, drove me mad for days!!
You did do as suggested and use a card reader on your computer to transfer the files, and not the Nokia supplied software. I found that you can copy the files over using the Nokia software, they will appear to be fine, but they will still not work.
the second I used the card reader, everything was fine.
dannygr27
PostPosted: Wed Mar 16, 2005 5:12 pm    Post subject: Reply with quote
hi yes using a car reader worked well they show on th poi but ive been past the speed camera down the road to me and it didnt warn me , i set it to warn at 300 yards and they are not showing on my maps
specihunter
PostPosted: Tue Apr 26, 2005 7:30 pm    Post subject: Reply with quote
Hi Danny
I got it to work by opening Explorer on my laptop. Opening the latest camera download form here. Then opening the ov2 and bmp file. Then transferring each file individually into my TomTom Mobile GB Maps on my MMC card ( through my card reader), and chooosing ok each time it asked if I wanted to replace the original file. Worked first time doing it this way.
PostPosted: Tue Apr 26, 2005 7:39 pm    Post subject: Reply with quote
Are you sure you didn't tick the 'warn only when on route' box? If you did then you only receive an alert if the camera is on an active route i.e.
