Pocket GPS World :: View topic - Bicycle audio
Bicycle audio
I00I0I0
PostPosted: Wed Mar 02, 2005 9:59 am    Post subject: Bicycle audio Reply with quote
On the external connector Pin 3 & 4 are for audio. But if I'm not mistaken will only produce audio if an external power source is connected.
Would it be possible to build a solution based on the handlebar mount that would produce audio on a bicycle?
Bart
http://www.softsolutions.be/GPS/startg.htm
GPS- & Navigation specialist
is_don_is_good
PostPosted: Fri Apr 08, 2005 12:33 pm    Post subject: Reply with quote
I will need to investigate the connector at some stage - how did you identify which pad carries the various signals? Do you know the others?
Don't you just hate proprietory connectors!
I did see somewhere that external power must be connected to get audio out of the Quest. This would suggest that external power is used for an internal audio amp. This makes sense as it would help extend battery llife - but is not much use if you want to get audio for on a bike. I did see somewhere a reference to a S/W update to allow volume control for a bikers ear buds...
There still seems to be a few things to work out here!
Any more wisdom out there?
ayresmas
PostPosted: Sun Apr 10, 2005 2:49 am    Post subject: Using Quest on bikes Reply with quote
I am most interested in using my Quest for bike riding and would appreciate having more information on having a connecting wire for a earphone, using the Quest inner battery!
22.053 (15 May 24)
