Pocket GPS World :: View topic - Switching maps
Switching maps
tracker
PostPosted: Tue Feb 15, 2005 2:22 pm    Post subject: Switching maps Reply with quote
Hi All,
From my understanding can use TT3 Navigator Maps on TT Mobile. I have copied the directory to the root of my Stoarge card. On other topics I have read that when your run the application, it will ask which map you want.
I my version this is not happen, any ideas?
Rolling Eyes
lbendlin
PostPosted: Tue Feb 15, 2005 3:29 pm    Post subject: Reply with quote
you can try to remove the sd card, run the program, exit the program, then reinsert the card and run the program again ( to initiate a folder scan)
Or you can use the registry editing method to point the program to the right map location.
Lutz
TomTom/TeleAtlas NAVTEQ
tracker
PostPosted: Tue Feb 15, 2005 4:50 pm    Post subject: Reply with quote
I have tried the removing the SD card, but no luck.
What is the reg path info?
lbendlin
PostPosted: Tue Feb 15, 2005 6:22 pm    Post subject: Reply with quote
HKCU\Software\TomTom\TomTom Navigator\Maps
Lutz
tracker
PostPosted: Wed Feb 16, 2005 10:08 am    Post subject: Reply with quote
Which is the best Regedit problem for my mobile C500
gstenson
PostPosted: Wed Feb 16, 2005 2:35 pm    Post subject: Reply with quote
Either PHM registry editor (which runs on your c500) or MobileRegistryEditor which runs on your PC.
Audi S4
HTC One M8 & CamerAlert
tracker
PostPosted: Fri Feb 18, 2005 4:12 pm    Post subject: Reg Reply with quote
I cannot find the follow location,
HKCU\Software\ This is no > TomTom\TomTom Navigator\Maps
lbendlin
PostPosted: Fri Feb 18, 2005 4:27 pm    Post subject: Reply with quote
then you have a more serious problem... You will need to reinstall TTN
Lutz
tracker
PostPosted: Mon Feb 21, 2005 2:13 pm    Post subject: regedit Reply with quote
Just to make sure that we are talking about the same application.
Why is the a TT Nav < name in the regedit for TOMTOM mobile.
Has anbody switched maps ? Because all the info on here and google, say that it is possilbe but nobody was tested it. ?
lbendlin
PostPosted: Mon Feb 21, 2005 2:59 pm    Post subject: Reply with quote
yes, the registry branch is the same.
I am switching maps routinely, so I can confirm that it works
Lutz
Soegaard
PostPosted: Thu Feb 24, 2005 2:23 pm    Post subject: Reply with quote
When you Lutz Bendlin are saying that you able to switch maps, are you talking about TomTom Mobile?
I am not able to do that either.
I have used PC Suite to load the Map into MMC.
As I can see on other threads for POI, that it is not posssible to load a working new POI using PC Suite, but had to use a program called DeskFileMan. Does the PC Suite cause the problem?
Soegaard
Lutz Bendlin
PocketGPS team
lbendlin
PostPosted: Thu Feb 24, 2005 3:37 pm    Post subject: Reply with quote
Yes, I am talking TomTom Mobile.
But I have never heard of PC Suite or DeskFileMan. What devices do you have, after all? A Mac and a Nokia?
Lutz
Soegaard
PostPosted: Thu Feb 24, 2005 4:00 pm    Post subject: Reply with quote
The PC Suite for Nokia 6600 have I used to to load the new map onto mu MMC.
The DeskTopFileManager ( http://www.symbianware.com/product.php?id=dfm&pl=n6600 ) have one in this forum used to solve problems with loading new POI into the Map in MMC. When using PC Suite the POI wupld not work.
I am using my PC with XP-Pro.
Soegaard
Soegaard
PostPosted: Thu Feb 24, 2005 5:08 pm    Post subject: Reply with quote
By using DesktopFileManager to load POI`s and Maps into the MMC, I have solved my problems.
DONT USE NOKIA`S PC SUITE FOR NOKIA 6600 TO LOAD FILES INTO THE MMC.
I hope this help alot of people here in this Forum.
Soegaard
22.053 (15 May 24)
