Pocket GPS World :: View topic - using the SCD database in Navman iCN510
Nigbo
PostPosted: Fri Feb 18, 2005 3:45 pm    Post subject: using the SCD database in Navman iCN510 Reply with quote
so if i follow the instructions as in daves 1st post at the top - do I only need to input the one file pocketgps_uk_gatso.csv to cover ALL speed cameras or do I also have to do the same for every other csv listed & do I input associated wav files or not - is there a voice warning already in the navman
MattB
PostPosted: Fri Feb 18, 2005 3:59 pm    Post subject: Reply with quote
The Gatso file holds all Fixed Gatso cameras. If you want to include the Mobile locations as well, you'll need to add that file (plus the Mobile BMP, so they look different to the Gatso ones).
Navman uses a default wav, called cosmicl.wav held in the sounds folder. You can replace that with different wavs, but it is probably best to have the same name, or else it may not be able to find it.
For safetys sake as well, keep a copy of the original somewhere else as well, in case you don't like the replacement.
Personally I kept the original wav sound
Nigbo
PostPosted: Fri Feb 18, 2005 4:12 pm    Post subject: Reply with quote
thanx MattB - exactly wot i needed to know
