Pocket GPS World :: View topic - about activating Europe maps on SD card
smartcruiserz3
PostPosted: Thu Jan 27, 2005 6:54 pm    Post subject: about activating Europe maps on SD card Reply with quote
I have a question about the activation code(s??) from the tomtomcode site.
I've already installed the MRE maps as well as the UK on a new 512mb SD card. It asked for the activation code when I opened up the UK maps and it was easy enough to go to the code site, input the serial number etc to obtain the code.
I haven't been to europe yet but will be in one weeks time, so...
Do I need an activation code for these maps too? or will the code I've put into activate the UK maps be sufficient?
Also I've bought another 512mb SD card and purchased the full maps of europe. This will also need another activation code? will the last one that I put into the first SD card work?
Sorry if this seems a bit gobblegook, it makes sense to me!!!
Thanks folks
PostPosted: Thu Jan 27, 2005 7:29 pm    Post subject: Reply with quote
I take it that you have bought your GO with UK mapping, and then have bought Maps of Western Europe seperatley.
Each of these will need to be activated. You can do this without going to Europe, simply by switching to one of the European maps. Once activated for one European map it should be for all maps. Make sure you do this before you go otherwise you will need to find an internet terminal when you get there.
You will be able to use the same activation codes for both SD cards. Make sure that you install the GO Navigator software to your new card.
SGR1913
PostPosted: Fri Jan 28, 2005 11:20 am    Post subject: Reply with quote
The activation code for the maps of Europe is hidden under the 4th cd in the box. Took me ages to find it, as i was only installing maps from CD1 at the time.
PostPosted: Fri Jan 28, 2005 11:30 am    Post subject: Reply with quote
SGR1913,
Was that the activation code or the product code?
Normally you need a product code to go online to get the activation code from www.ttcode.com .
SGR1913
PostPosted: Fri Jan 28, 2005 11:38 am    Post subject: Reply with quote
product code. It just in such a bizarre place, that it's not immediately easy to find.
nich
PostPosted: Fri Jan 28, 2005 10:29 pm    Post subject: Reply with quote
I have just install the frence maps on cd 4. after an age of looking i have found the autherization code but because of bad printing cant make out some of the digits. how can i get copies of the code or what else can i do. we leave for france next week.
rkm_hm
PostPosted: Fri Jan 28, 2005 11:41 pm    Post subject: Reply with quote
Get a big magnifying glass? Smile
22.052 (08 May 24)
