Pocket GPS World :: View topic - Problem using TTN3 with battery
alice_anto
PostPosted: Sun Jan 02, 2005 5:03 pm    Post subject: Problem using TTN3 with battery Reply with quote
Hi all,
i have this problem since last week, when i upgrade my 2210 bios to 1.1
Now if i use 2210+gps+ttn3 using battery, after few minutes (as set in backlight panel) the pocketpc go in stad-by.
I have already set the slide to little red hands but go in stand-by anyway.
Please, someone konw can i check ??
many thanks
PostPosted: Sun Jan 02, 2005 7:39 pm    Post subject: Reply with quote
Ciao,
that's a tricky one. Normally it should work. Which version of the GPS driver are you using? Maybe re-installing the GPS 2.07 helps
alix776
PostPosted: Sun Jan 02, 2005 8:34 pm    Post subject: Reply with quote
when you say it goes in to standby do you mean the backlight goes out so the screen becomes dull if that is the problem then follow this
start>settings>backlight> the next screen is the one you need uncheck the top box and that should do it ok to exit the screen
device Lumia 950 xl
alice_anto
PostPosted: Sun Jan 02, 2005 9:03 pm    Post subject: Reply with quote
just reinstalled the gps 3.07 but still there. (2210 turn off itself)
Of course if i uncheck the checkbox in advanced power safe setting the 2210 stay on but this can be dangerous for the life of my battery Smile
Before i had installed 1.1 rom i'm sure that 2210 stay on when the ttn3 was open....
PostPosted: Mon Jan 03, 2005 1:41 am    Post subject: Reply with quote
Not 3.07 - 2.07... can you try that?
alice_anto
PostPosted: Mon Jan 03, 2005 9:13 am    Post subject: Reply with quote
ciao lbendlin,
just installed 2.07 downloded from pocketgps but with the same results: pocketpc turnoff Evil or Very Mad
Can you check in notify events database if are there entry generated by ttn3 ??
PostPosted: Mon Jan 03, 2005 3:07 pm    Post subject: Reply with quote
yes, you can. but the only event you will find is a WAKEUP event linked to ttgpseng.exe . Your situation is different
use check_notifications.exe
alice_anto
PostPosted: Tue Jan 04, 2005 12:08 am    Post subject: Reply with quote
yes, i have found it but still the problem Smile
Anyway... i will uncheck the 'stand by after x minutes' checkbox before running ttn3 Embarassed
