Pocket GPS World :: View topic - Driver?
Driver?
gotskov
PostPosted: Fri Dec 12, 2003 9:57 am    Post subject: Driver? Reply with quote
I have ipaq 2210, Globalsat bc-307 and tomtom 2 (ver 2,24 and gps 2,08)
Currently im using GNS GPSCARD CF2 driver. Is there one that will work better?.
I wanna know if there is a difference if i use another driver or if it is "if it work it works"?
PostPosted: Fri Dec 12, 2003 11:17 am    Post subject: Reply with quote
Personally I would use the NMEA driver, it's not optimised, but in most cases that can be an advantage.
gotskov
PostPosted: Fri Dec 12, 2003 6:36 pm    Post subject: Hi Dave... Reply with quote
.....and thanks for your reply.
I tried the driver you proposed and i actually thinks that i works better than the one i used to use.
Can that really be?
PostPosted: Sat Dec 13, 2003 11:02 am    Post subject: Reply with quote
What happens is that TomTom don't always have the hardware to test, so they go on specs and will setup a driver for a GPS Receiver and set what they think is correct. This can sometimes make the card operate badly by thinking it should operate like another card. The NMEA drivers are untouched and raw, so I always find that it's best to use these where possible. The only exception I would say would be for the TomTom Navigator driver where this works with LeadTek's very well, and also the Emtac Wireless GPS which works well for all Bluetooth GPS Receivers.
gotskov
PostPosted: Sat Dec 13, 2003 11:06 am    Post subject: Thanks Reply with quote
I will stick to NMEA drivers. It also seems like the reception is better with NMEA, so thank gor the help.
balmoralboy
PostPosted: Fri Dec 03, 2004 8:57 pm    Post subject: Reply with quote
Where would I get the NMEA driver? For a SD-510?
