Pocket GPS World :: View topic - Use multiple countries maps?
peter_rjs
PostPosted: Fri Nov 26, 2004 1:02 pm    Post subject: Use multiple countries maps? Reply with quote
I have been using UK & Ireland map, all working well. Location is on my SD card;
\SD Card\Maps\Great Britain and Ireland
I exported the Belgium map to the same \Maps directory so now I have two folders in the Maps directory;
\Belgium
When I tap "Country - Please Select" it offers the following;
France
Great Britain
Ireland
Norway
The Netherlands
Only Great Britain and Ireland have any map data - the others have none.
I cannot get Belgium to appear.
The only way I can get the Belgium map to work is if I edit the "NavLib.ini" file in the main Navigon directory.
\Program Files\Navigon\MobileNavigator4.0\NavLib.ini
[Properties]
Last used database directory=\SD Card\Maps\Belgium
Editing the last part of the path under properties to be Belgium, instead of Great Britain and Ireland.
Now the "Country" field is already filled with "Belgium", and the map data is available. No other Country choices are offered.
This is obviously not the correct way this should work - any ideas?
Peter
hp2210 & Panasonic SD 512Mb
Navigon 4.2 & BT & TMC
POI Warner MN4
zedhal
PostPosted: Wed May 25, 2005 1:50 am    Post subject: Reply with quote
Your navigon software has a specific option in it, it should be right at the start as it starts up, a button, probably named something as SELECT MAP.
This option should take you to the next screen where you will have two arrows, upwards and downwards, allowing you to scroll through all of the maps that you have on the SD card memory.
And you are right to place the maps in the same directory but still for them to have their own directories, as in
\UK ...
\FRANCE..
\ETC...
