gasman100 Occasional Visitor
Posted: Tue Oct 05, 2004 11:11 pm Post subject: no pocketgps poi tab in navigator |
I have a hp2210 have downloaded checkpoint 2.02 ok also downloaded database onto sd card but when i start Navigator, goto properties to poi tabs there is no POCKETGPS UK SC tab to check ,only a checkpoint tab ,which i have checked but has not made any difference please point me in the right direction im new to this and am nearly bald from ripping my hair out in despair |
Beefy Regular Visitor
Joined: Aug 06, 2004 Posts: 107 Location: Bucks, United Kingdom
Posted: Sun Oct 10, 2004 9:50 am Post subject: |
Stop ripping your hair out! And
You need to put the PocketGPS databases in the same place that your Navigator map is in. I have a feeling that you haven't done this.
If your map data for Navigator is on the SD card make sure it is in the same directory, then you will see the icons to select when you go into Properties=>POI. _________________ Beefy
High Quality Pubs - http://www.pocketgpspoi.com/reviews/tomtompoi/High_Quality_Pubs.zip
TomTom ONE |
Posted: Sun Oct 10, 2004 8:27 pm Post subject: |
Thanks for assitance ,I checked on contents of sd card found navigator map ok ,within directory is file pocketgps_uk_sc but still no poi tab am i missing a file? |
Darren Frequent Visitor
Posted: Sun Oct 10, 2004 8:48 pm Post subject: |
For each database you need the database.ov2 and database.bmp files. You can see the file extensions if you browse to your storage card from the PC via ActiveSync. _________________ Darren Griffin |
