I don't have a TTGo to check, but on the Palm version the 'user' preferences ( Favourites, Recent Destinations, Address searches, POI settings etc ) are all stored in a file with the extesion .cfg, the name is that of the map it relates to.
I should say that if you delete this file it will sdo as you want, but will remove all of your favourites, home settings etc
The file format is very similar to the TTNav2 .ov2 format and if you want to try you could go hacking with a Hex editor to remove the desired locations....
however, if you for whatever reason have to erase your tracks, you can backup the file that holds the last destinations. go wherever you go and when back, restore this file.
for the benelux, it's the file Benelux-Map.cfg for instance. in fact, if you know the format you could edit it.
