Pocket GPS World :: View topic - TomTom Go
TomTom Go
Falkien
PostPosted: Fri Sep 10, 2004 10:15 am    Post subject: Reply with quote
I don't have a TTGo to check, but on the Palm version the 'user' preferences ( Favourites, Recent Destinations, Address searches, POI settings etc ) are all stored in a file with the extesion .cfg, the name is that of the map it relates to.
GB Navigator Map.cfg & Major_Roads_Of_Europe Navig.cfg
on the Palm they are stored in the organisers memory, not on the SD card
HTH
Falkien
PostPosted: Fri Sep 10, 2004 10:18 am    Post subject: Reply with quote
I should say that if you delete this file it will sdo as you want, but will remove all of your favourites, home settings etc
The file format is very similar to the TTNav2 .ov2 format and if you want to try you could go hacking with a Hex editor to remove the desired locations....
Falkien
PostPosted: Fri Sep 10, 2004 1:28 pm    Post subject: Reply with quote
Confused wonder where they are stored then?
been googling and found this reference
http://www.totalpda.co.uk/forum/showthread.php?s=8a2986411a0d0390b285dbd7c9fc1140&p=3781
on the totalgps forum
however, if you for whatever reason have to erase your tracks, you can backup the file that holds the last destinations. go wherever you go and when back, restore this file.
for the benelux, it's the file Benelux-Map.cfg for instance. in fact, if you know the format you could edit it.
/is confused/
Sorry I couldn't be of more help
