Pocket GPS World :: View topic - Compact Flash card - help needed
Pete2
PostPosted: Mon Aug 09, 2004 4:24 pm    Post subject: Compact Flash card - help needed Reply with quote
I've got a samsung 512mb compact flash card which i've got to use with my old jornada 568. When i first received it i could access it in my pc card reader / writter and on the jornada. Now if i put it in my pc it freezes the system, if i put it in the jornada i'm prompted to format it, tap yes and i then get an error message "an error occured while formatting the Srorage Card ( error code 31)".
Can anyone shed any light on this problem - is there a way to reset the card?
Pete
drummer
PostPosted: Mon Aug 09, 2004 4:37 pm    Post subject: Reply with quote
Try the programme below. Install this on your Jordana, then you can scan, format or defrag your card. Thumbs Up
http://www.softwinter.com/storagetools.html
Pete2
PostPosted: Mon Aug 09, 2004 4:47 pm    Post subject: Reply with quote
Thanks Drummer,
I've just installed and run a similar program called "flash format" which you can install and use for 14 days free (evaluation period). When i insert the 512mb card the program doesn't detect its presence, says "please insert storage card" thou the system still trys to format it and still gives the same error message.
I'm assuming that i've somehow managed to corrupt the card beyond recovery Crying or Very sad but i'll keep trying.
Thanks for the pointer thou
Pete2
22.052 (08 May 24)
