Pocket GPS World :: View topic - Which Database for KIA Sportage?
walkabout
PostPosted: Sun Feb 13, 2022 3:27 pm    Post subject: Which Database for KIA Sportage? Reply with quote
Hi Guys,
I have a 2016 KIa Sportage.
The Satnav I believe as mentioned in the manual is Tom Tom based.
It can take custom POI's,, but only gpx or kml.
Which data base could I use?
I also believe it's a Win CE system?
PostPosted: Mon Feb 14, 2022 8:42 pm    Post subject: Reply with quote
'TomTom' will likely be the mapping rather than the navigation itself.
We have both GPX and KML available. Look for 'Garmin - Other' and you can find GPX there.
walkabout
PostPosted: Fri Feb 18, 2022 2:28 pm    Post subject: Reply with quote
Hi MaFt,
I had a look and under Garmin there is no "other" in the Garmin or GPX or KML listed, only CSV?
Unless I'm being a bit thick and can't see it?
Mark
PostPosted: Fri Feb 18, 2022 5:46 pm    Post subject: Reply with quote
Scroll down the list, It's under Excel
walkabout
PostPosted: Wed Feb 23, 2022 6:47 pm    Post subject: Reply with quote
Thanks guys,
Manged to find the download and the head unit took in some of the POI's.
It seems the Sportage can only have 5000 entries and the database is currently 9,450 without pmobile.
So back to the drawing board.
Any ideas, or should I just give up?
Is there a way of just selecting say South of England or Birmingham down?
Mark
PostPosted: Thu Feb 24, 2022 6:49 am    Post subject: Reply with quote
The other thing to check, as many have found, is - can you set these POI's as cameras, that require an advance warning, or just POI's you can only navigate to.
PostPosted: Tue Mar 01, 2022 1:43 pm    Post subject: Reply with quote
You'd need to order the POIs in the file by Latitude and then remove anything higher than, say 52.48
walkabout
PostPosted: Thu Mar 03, 2022 9:31 am    Post subject: Reply with quote
Thanks MaFt,
I will give that a try.
Mark
pitchnearly
PostPosted: Tue Jun 06, 2023 2:37 am    Post subject: Reply with quote
I tried and found it. Thank you very much.
22.111 (06 Nov 24)
