alice_anto Occasional Visitor
Joined: 14/03/2003 13:54:05 Posts: 16 Location: Italy
Posted: Sun Jan 02, 2005 5:03 pm Post subject: Problem using TTN3 with battery |
Hi all,
i have this problem since last week, when i upgrade my 2210 bios to 1.1
Now if i use 2210+gps+ttn3 using battery, after few minutes (as set in backlight panel) the pocketpc go in stad-by.
I have already set the slide to little red hands but go in stand-by anyway.
Please, someone konw can i check ??
many thanks |
lbendlin Pocket GPS Staff
Posted: Sun Jan 02, 2005 7:39 pm Post subject: |
Ciao,
that's a tricky one. Normally it should work. Which version of the GPS driver are you using? Maybe re-installing the GPS 2.07 helps _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
alix776 Pocket GPS Moderator
Posted: Sun Jan 02, 2005 8:34 pm Post subject: |
when you say it goes in to standby do you mean the backlight goes out so the screen becomes dull if that is the problem then follow this
start>settings>backlight> the next screen is the one you need uncheck the top box and that should do it ok to exit the screen _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sun Jan 02, 2005 9:03 pm Post subject: |
just reinstalled the gps 3.07 but still there. (2210 turn off itself)
Of course if i uncheck the checkbox in advanced power safe setting the 2210 stay on but this can be dangerous for the life of my battery
Before i had installed 1.1 rom i'm sure that 2210 stay on when the ttn3 was open.... |
Posted: Mon Jan 03, 2005 1:41 am Post subject: |
Not 3.07 - 2.07... can you try that? _________________ Lutz
Posted: Mon Jan 03, 2005 9:13 am Post subject: |
ciao lbendlin,
just installed 2.07 downloded from pocketgps but with the same results: pocketpc turnoff
Can you check in notify events database if are there entry generated by ttn3 ?? |
Posted: Mon Jan 03, 2005 3:07 pm Post subject: |
yes, you can. but the only event you will find is a WAKEUP event linked to ttgpseng.exe . Your situation is different
use check_notifications.exe _________________ Lutz
Posted: Tue Jan 04, 2005 12:08 am Post subject: |
yes, i have found it but still the problem
Anyway... i will uncheck the 'stand by after x minutes' checkbox before running ttn3 |
