Jammer Regular Visitor
Posted: Sun Aug 29, 2004 11:07 pm Post subject: Is the Fortuna charge OK for my iPaq? |
I was pleasantly surprised to find that the Fortuna charger has two power leads.
Which means I can charge both the Fortuna Clip On and my iPaq.
But... that's what I'm not sure about...?
IS it OK to charge my iPaq?
The power lead, as long as you have the relevant adapter, could charge any other PDA.
Surely different models have differen voltage or current requirements?
This now means that I don't have to get a holder to charge my iPaq.
I wouldn't have used the holder to view directions anyway.
The sound directions are more than fine for me.
Any feedback would be appreciated.
Thanks.
OM _________________ iPaq 3870
Fortuna Clip On Bluetooth
Tomtom
London
Currently testing Fortuna to see if it's any good! |
harry66 Regular Visitor
Joined: Nov 17, 2003 Posts: 62 Location: United Kingdom
Posted: Tue Aug 31, 2004 1:17 pm Post subject: |
I used the extra connector to charge my Dell Axim X30 and it appeared to go OK. Doesnt mean it is OK to do this - just letting you know it worked for me and I havent noticed any side effects (has only been a few days since I tried) |
Posted: Tue Aug 31, 2004 1:33 pm Post subject: |
I'll email Fortuna and see what they say.
I'll post any reply to this message. _________________ iPaq 3870
Tomtom
London
MarkH Occasional Visitor
Posted: Tue Aug 31, 2004 2:41 pm Post subject: |
I'm dealing with this issue at the moment too. I don't have the clip-on charger with me but I think it's 850mA output. Check your charger but I think PDA chargers usually have a 1A output. So when charging the GPSR and PDA you'll supply them with 425mA each. PDAs can be charged from a USB port which is around 500mA. Basically I don't think they'll be any harm in charging the PDA but it will take longer to charge because of the lower current.
You might be able to charge your mobile from the same charger using:
http://www.expansys.com/product.asp?code=EXP_UTC-NO2
I have a nokia charger that has 5.7v/800mA output
I've ordered a USB travel charger, hopefully it will work ok with the clip-on/PDA (5.5v/1A output I think)
http://www.expansys.com/product.asp?code=EXP_USB-TC-EU |
Posted: Tue Aug 31, 2004 2:50 pm Post subject: |
On a related issue does anybody know a place (on-line or off) where I can get a US-Europe plug adapter in the UK. It would turn the Clip-on's charger into a travel charger since it already comes with US and UK plugs. |
scotty2 Occasional Visitor
Posted: Tue Aug 31, 2004 3:15 pm Post subject: |
I use the Fortuna charger with an ipaq 4150 and it works OK. One thing I have noticed when use the lighter socket in the car is that the ipaq charging LED (red) does not blink if I have both devices charging at the same time so I play safe and charge them seperately. |
Posted: Wed Sep 01, 2004 11:53 am Post subject: |
Just had a reply from Fortuna:
"Yes, it is ok to charge your Ipaq with our standard Clip-On charging cable. "
Tomtom
London
bournea Occasional Visitor
Posted: Fri Sep 17, 2004 9:13 am Post subject: |
In reply to MarkH's request (probably to late now), the 2 places good for electronic accessories are:
1. on-line = www.CPC.co.uk
2. shops = Maplins (also on-line www.maplins.co.uk)
Hope this helps
Adrian |
