Pocket GPS World :: View topic - nuvi 205 chime to speech warning help needed
gav311
PostPosted: Tue Feb 08, 2011 11:21 am    Post subject: nuvi 205 chime to speech warning help needed Reply with quote
Hi, when can we expect the video of the garmin nuvi chime to speech warning tutorial as i can seem to master the conversion.
Regards, Gavin
Talbotsunbeam
PostPosted: Sun Mar 20, 2011 11:28 pm    Post subject: Did you ever get an answer. Reply with quote
Hi, I have the same problem following the instructions on this site, and still not working.
PostPosted: Mon Mar 21, 2011 12:00 am    Post subject: Reply with quote
Do you both have Nuvis that have mp3 players?
There are different instructions for those that do and those that don't.
Assuming you are following the instructions HERE, post back with more details of what models you have, and at what point the installation goes wrong for you.
Talbotsunbeam
PostPosted: Fri Apr 01, 2011 5:51 pm    Post subject: Solved But! Reply with quote
Hi, Yes I have a Nuvi 765 with mp3, I have got the speech working by using the correct database format, but I now have another problem that many of the cameras have multiple warinings. Some are nearly half a mile from the camera position. Think I may go back to the warning tones. Confused
dales
PostPosted: Fri Apr 01, 2011 8:06 pm    Post subject: Reply with quote
Have you made sure to turn off the Garmin (Cyclops) cameras?
They could well be causing the rogue alerts.
Dales.
PostPosted: Sun Apr 03, 2011 1:50 am    Post subject: Re: Solved But! Reply with quote
Or have you left the OTHER database version in your upload folder as well?
Although if the warnings are in the wrong place, I would suspect Cyclops instead.
Whatever the problem is, it's nothing to do with the voice warnings themselves.
