Pocket GPS World :: View topic - BeanBag for a TomTom 730. Sounds wise but which one?
Goto page Previous  1, 2
Calomax
PostPosted: Sat Jul 18, 2009 3:23 pm    Post subject: Reply with quote
Mike, I don't have an easyport mount. The connector on the power cable that was supplied with my 720 is right-angled so points to the back. But, I've only used the beanbag mount with the USB RDS-TMC, and its connector is straight and points straight down.
TT Go Essential
PostPosted: Sat Jul 18, 2009 8:50 pm    Post subject: Reply with quote
mikealder wrote:
as I recall the power cable for the x30 is slightly different to the ones supplied with the x20, the newer cable having the outlet pointing to the back of the device rather than the side - Mike
Other way round?
My original 720 charger has the cable exiting the USB plug to the rear, but my newer chargers for the 940 and the XL have it coming out to the side.
Alabama978
PostPosted: Sun Jul 19, 2009 11:04 am    Post subject: Another mount Reply with quote
Anyone tried this one?
http://www.buybits.com/product/sku_3424.aspx
I'm thinking of getting it for my 720 as I do a lot of short trips each day and get fed up removing the suction mount.
From a safety point of view I note the warning about airbags. Keep the mount away from any area where an airbag could deploy, otherwise it could become a lethal projectile if the airbag propels it toward you at warp speed Wink
I hate to see loose equipment anywhere in a car and cringe when I see an umbrella on a back window shelf or seat. Anyone who has ever been in an accident knows how stuff can fly around and injure people.
Brickie64
PostPosted: Sun Jul 26, 2009 7:18 pm    Post subject: Reply with quote
This is the first friction mat I've seen for TomTom GO that doesn't use a suction device to mount it. This looks a promising unit but it's not clear from the photos whether you'll get enough clearance at the bottom of the TT GO when the screen is vertical and the mat is sitting on a horizontal dash.
I think the suction mounts on these friction mats is the weak point especially when you move it between cars all the time, any small scratch on the plastic suction surface means you need to replace it with a new disc to make it stick.
"A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible"
Garmin Nuvi 3598 + GO 720 (+USA Map Card) + NavFree for iPhone in case all else fails ;-)
TangoCharlie
PostPosted: Wed Jul 29, 2009 9:40 am    Post subject: Reply with quote
Hi folks
just received the Arkon. Not impressed with the adaptor for my TT730. It doesn't fit flush into the TT as the diagram appears and then it sits losely on the Arkon arm.
How do yours fit?
"Keep it Simple, Stupid"
MrT
PostPosted: Wed Jul 29, 2009 9:49 am    Post subject: Reply with quote
Mine is a very good fit, it may seem obvious but assuming yours is the same as mine when you look at the bit the Go clips on to, it does look like a "T" and is not on the wrong way up?
Drivelux
TangoCharlie
PostPosted: Wed Jul 29, 2009 4:33 pm    Post subject: Reply with quote
thanx for the reply. I think it's the correct way up, so it then drops onto the arm mech.
But that clip doesn't sit flush to the back of the TT. It just won't press right into the TT.
Tc
MrT
PostPosted: Thu Jul 30, 2009 7:33 am    Post subject: Reply with quote
I take it that your mount plate looks like these? You can see the T shape and it orientation in these pictures.
They seem to list different parts for the various Go's but I thought they were identical mounts, particularly in the same range.
Drivelux
TangoCharlie
PostPosted: Thu Jul 30, 2009 8:43 am    Post subject: Reply with quote
Maybe I got the wrong adaptor thing. It looks the same as in the photo though.
It's not a huge issue but it doesnt sit flush in the TT.
Pieman1972
PostPosted: Fri Jul 31, 2009 9:33 am    Post subject: Reply with quote
720 Owners - beware.........
I have a reconditioned 720 bought in May this year. I have checked the windscreen mount supplied with my set and the arm is not long enough to get the power plug in etc when positioned in the middle of the dash. I would need to position the unit of the edge of the device.......
So I'm now looking for the beanbag and attachment......
Pieman1972
PostPosted: Fri Jul 31, 2009 2:03 pm    Post subject: Reply with quote
Ordered one with the mount from Handtec - should be here Monday/Tuesday............
TangoCharlie
PostPosted: Thu Aug 06, 2009 7:51 pm    Post subject: Reply with quote
My Mums got an old TomTom Go One. Will the Arkon Non-Skid / Friction Style Weighted Dash Mount work with it?
Thanx
MrT
PostPosted: Fri Aug 07, 2009 8:30 am    Post subject: Reply with quote
It will work as long as you can get the correct adaptor plate for it.
Drivelux
Page 2 of 2
22.051 (01 May 24)
