Pocket GPS World :: View topic - NEW MAPS FOR TOM TOM (18 MAY)
Goto page Previous  1, 2, 3, 4, 5
Nigel42
PostPosted: Wed May 20, 2009 10:38 am    Post subject: Reply with quote
Hers another one I've been banging on about for years. No right turn from Horse Guard Ave into Whitehall (small street near to where a lot of fiddlers 'work')
New map? TT STILL trys to make you perform a right turn.
Google = http://maps.google.co.uk/maps?f=q&source=s_q&hl=en&geocode=&q=horse+guard+ave+london&sll=53.800651,-4.064941&sspn=14.723988,39.550781&ie=UTF8&ll=51.506071,-0.125635&spn=0,359.980688&z=16&iwloc=A&layer=c&cbll=51.504863,-0.126101&panoid=m_Fdf7b36bHUy_SlqkZZlQ&cbp=12,294.06,,0,5
Its been there for YEARS
weelogic
PostPosted: Wed May 20, 2009 10:41 am    Post subject: Reply with quote
I have finally completed the download, only to get an error message saying "Item was not valid after installation". I now have no maps at all on my device. Any suggestions?
MrT
PostPosted: Wed May 20, 2009 10:43 am    Post subject: Reply with quote
Could it be you have a Go9x0 and were installing the Western and Central Europe map V 830?
Drivelux
weelogic
PostPosted: Wed May 20, 2009 10:55 am    Post subject: Reply with quote
I've got a 940 and was installing map Western and Central Europe 830.2305, which was the map that Home offered me under the Map Update subscription. Is that not the correct map for the device?
MrT
PostPosted: Wed May 20, 2009 11:17 am    Post subject: Reply with quote
How about reading this forum topic Home will not install new maps?
Drivelux
weelogic
PostPosted: Wed May 20, 2009 12:28 pm    Post subject: Reply with quote
MrT, many thanks. I searched the forum on the error message but missed that thread. Extracting the downloaded file worked the trick, Home sees the map and recognises it as a valid install.
I love this site :-)
nbg
PostPosted: Wed May 20, 2009 10:27 pm    Post subject: Reply with quote
Andy_P wrote:
exportman wrote:
If you copy the new map over in TTH it should keep your original alerts.
Not necessarily true....
nbg - the file you need is MapSettings.cfg
Sometimes this file remains compatible after a map or software change sometimes it doesn't.
To try it, just copy that file from the old map folder (from a backup or before you update) and paste it into the new folder.
either it will work and you will keep all your settings, favourites etc. or it won't.
If it doesn't, one of two hings will happen. Either it will get replaced with a fresh copy, or the TomTom will refuse to start up and will continuously reboot.
To rectify that, either give up and remove the file you copied or some people have found you can "fix" the file by running the on-screen emulator in Home and saving a new favourite.
Thanks Andy, that di do the job. As Tom reported, I didn't need to make a change, just opened and closed the emulator and that stoped the reboots Very Happy
thetrotter
PostPosted: Wed May 20, 2009 11:06 pm    Post subject: Reply with quote
I've just 'rolled' back to the last map and Navcore.
The latest map loaded with installation errors so that I was effectively without a european and I couldn't fix with Mr T's input - I tried to extract from the Home cab but maybe I misread the instruction. Perhaps someone can paste a clearer solution.
I can only hope that TT fix it properly - and I'll try again.
If only we hadnt subscribed to the Map service there would have never been a moments angst! (Are these updated maps actually updated at all? Given the comments here it seems they have new release numbers but precious little 'new')
TT Go 920T
Navcore: APP 8.393 WORKS.
Map: Western Europe v845.2645
PGPSWorld Speed Camera Database (naturally)
PostPosted: Wed May 20, 2009 11:11 pm    Post subject: Reply with quote
Map install problem fixed..... try a new download.
You will need to delete the first download.
thetrotter
PostPosted: Wed May 20, 2009 11:22 pm    Post subject: Reply with quote
Was it fixed post 4pm today (uk) - that's when I installed it?
TT Go 920T
Pieman1972
PostPosted: Wed May 20, 2009 11:56 pm    Post subject: Reply with quote
Not sure if relevent - but I rang TT this morning re my LMG and when taliking to them advised that would be easier from home, so rang teatime....there was a mention about new maps not installing and refer to website....
I'm sure (happy to be corrected) there was a *NEW* document about being iunable to install maps.....
HTH
p60
PostPosted: Fri Jun 19, 2009 12:34 am    Post subject: Reply with quote
if you dont know Plaistow London and you try to get onto the A13 coming from the station along the A112 using the the latest tomtom maps you will end up going around in circles no slip roads going on or off the junction it was finished 9 years ago.more money I've wasted on these so called updated maps. GET YOUR ACT TOGETHER TELEATLAS
Page 5 of 5
21.094 (27 Sep 23)
