zzr1200 Lifetime Member
Joined: Jun 05, 2005 Posts: 205 Location: Gloucestershire
Posted: Mon May 18, 2009 3:18 pm Post subject: What is the best 'Day' colour scheme? |
Guys,
I fancy a change from my standard Britanica and want to know what DAY colour scheme people reckon is the clearest and easiest to read.
I only use my TT on 2D mode if that makes a difference and I really would like the motorways to be in blue so that they stand out in 'Browse Map' view.
PS - I know you can create your own scemes but I'd rather use one that has already been designed.
Thanks |
Andy_P Pocket GPS Moderator
Posted: Mon May 18, 2009 4:18 pm Post subject: |
I find the best for me in the UK is a scheme called "GB_New".
I got it from the Colour Scheme Editor website, but it might be on Home as a download too by now.
http://www.colorschemeeditor.com/index.php?p=schemes&lang=EN
It's under the "Schemes 1" tab (along with another one called "UK_Alt" which I didn't like so much). |
gary10 Lifetime Member
Posted: Mon May 18, 2009 4:21 pm Post subject: |
I like the AA Atlas colour scheme from Tom Tom. Its got blue M-ways green A-roads and yellow B-roads just like the atlas. _________________ Time for bed says Zebadee
TomTom 720 |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Mon May 18, 2009 5:54 pm Post subject: |
I'm with Andy_P - I use "GB_New". Motorways are red, and they do stand out. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21 |
253 Lifetime Member
Joined: Mar 05, 2007 Posts: 1058 Location: The green bit between the M40, M4 and M25.
Posted: Mon May 18, 2009 7:28 pm Post subject: |
I have both, but use the AA colours as well. It just seems better on the eye. _________________ Triumph Tbird 1700. And now a Bonnie T100. |
pEst_29 Occasional Visitor
Posted: Mon May 18, 2009 7:57 pm Post subject: |
I tried to install some schemes from that website but they're not working, not sure what I'm doing wrong:
- I placed them in the 'schemes' folder, they all have .clr extensions
- They show up under 'plugins' in my device (Go730) and I can select one for day and one for night
- back to map and... default colours!
Any ideas?
(I do have a signal by the way, it's not the greyed out map I'm getting) |
Rick-uk Lifetime Member
Joined: Apr 16, 2006 Posts: 320 Location: BS20, North Somerset
Posted: Mon May 18, 2009 8:10 pm Post subject: |
I use Os_Atlas_2 which I find is closest to a OS map
I would like this as a night scheme as well if I could just turn down the brightness on all the colours.
One day I will get around to it... |
Fozzee Regular Visitor
Posted: Mon May 18, 2009 8:46 pm Post subject: |
253 wrote: |
I have both, but use the AA colours as well. It just seems better on the eye. |
Where can I get this scheme from? |
Seamaster Frequent Visitor
Posted: Mon May 18, 2009 9:09 pm Post subject: |
Fozzee wrote: | Where can I get this scheme from? |
Via TomTom Home download. Search for "AA Map" in colour schemes. |
GerryC Pocket GPS Moderator
Posted: Tue May 19, 2009 9:53 am Post subject: |
pEst_29 wrote: | I tried to install some schemes from that website but they're not working, not sure what I'm doing wrong:
Any ideas?
It sounds like you are using Home to do the change (".clr", "plugins"). Try changing them via the change colours option in the preferences menu on the 730 itself when not connected to the PC.
What scheme is used for Browse Map? _________________ Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount |
Posted: Tue May 19, 2009 9:56 am Post subject: |
Rick-uk wrote: | I use Os_Atlas_2 which I find is closest to a OS map
I had a similar idea. As the .clr files are just text files that you can edit in Notepad etc, I made a new scheme up using the road colours from the 'day' scheme and the background colours from my preferred 'night' scheme.
Using black for the "countryside" background is a good start. _________________ Gerry
TomTom730T
Posted: Tue May 19, 2009 10:18 am Post subject: |
GerryC wrote: | pEst_29 wrote: | I tried to install some schemes from that website but they're not working, not sure what I'm doing wrong:
Any ideas?
What scheme is used for Browse Map? |
No, I was doing it on the device.
I found that if I download schemes via Home I could make them work, but not via that website. If I download via Home it installs 2 files, one .clr and another one whose extension I can't recall. It seems I have to have both files and not just the .clr one for it work...? If I get it from that website I only get a .clr file... |
Posted: Tue May 19, 2009 1:50 pm Post subject: |
Anita wrote: | I'm with Andy_P - I use "GB_New". Motorways are red, and they do stand out. |
I only just noticed this...
On my copy of 'GB_New', motorways are blue!
(Unless you're following a route on them of course... then they're the "on route" colour, which *is* red) |
Posted: Tue May 19, 2009 1:56 pm Post subject: |
pEst_29 wrote: | [If I download via Home it installs 2 files, one .clr and another one whose extension I can't recall. It seems I have to have both files and not just the .clr one for it work...? If I get it from that website I only get a .clr file... |
I've only ever done direct copy and paste to install the colour schemes, never used Home.... Just putting the one .clr file in the "schemes" folder has worked every time.
Th"other" file you got from the Home downloads is probably a .tlv file. Home seems to use these to get the info about the file which it writes up on the PC screen in home. It isn't used by the TomTom itself at all. |
Posted: Tue May 19, 2009 2:27 pm Post subject: |
Andy_P wrote: | pEst_29 wrote: | [If I download via Home it installs 2 files, one .clr and another one whose extension I can't recall. It seems I have to have both files and not just the .clr one for it work...? If I get it from that website I only get a .clr file... |
Bizarre then... No idea why the .clr doesn't work when downloaded from that website and placed in the schemes folder, but works when downloaded from home, coming with the .tlv... |
