dcgh2007 Occasional Visitor
Posted: Sun Apr 19, 2009 3:35 pm Post subject: 720 wont show cameras |
we had a problem with my 720 which we have now resolve by doing a complete reinstall however although the cameras are in the tomtom western europe file and ticked on poi's they do not show and i am about to travel 500 mls + through the most hostile camera areas, not for fun, so it would be a great help if someone could point me in the right direction
ps i have tried rest device etc |
Posted: Sun Apr 19, 2009 3:38 pm Post subject: |
Have you put the cameras into the correct map folder, for example you might have a map on the SD card and another on the internal flash memory - you need to know which is the currently active map and make sure the POI files are in the right folder.
Secondly open the Western_Europe map folder using Windows xplorer and see how many ov2 files there are within the map folder, if its over 169 this will be the problem as there is a limmit to the number of custom POI files you can install - Mike |
Posted: Sun Apr 19, 2009 3:56 pm Post subject: |
hi mike thanks for quick reply . no card all on internal. not sure about your second point on the tom tom 720 i have a pois folder but all the cameras are in western europe??
gerry |
Posted: Sun Apr 19, 2009 4:14 pm Post subject: |
hi mike
i think i have it. when i went back in to check i tried to 'change maps' it appears that i may have been set as 'canary isles' on the reinstall......old mens problems, looks ok now , hope the weather is as good down there as it is up here.
thanks again for the prompt |
keenrw Occasional Visitor
Posted: Mon Apr 20, 2009 9:28 pm Post subject: |
mikealder wrote: | Have you put the cameras into the correct map folder, for example you might have a map on the SD card and another on the internal flash memory - you need to know which is the currently active map and make sure the POI files are in the right folder.
Does this apply to the 740 live too ? im getting one soon but im a bit worried about the POI limit .. i would only use the speed cams for the UK and no other custom POI.
Rich |
Andy_P Pocket GPS Moderator
Posted: Mon Apr 20, 2009 9:38 pm Post subject: |
keenrw wrote: |
Rich |
The 169 limit applies to the 740 too, but you've no need to worry.
That limit doesn't include the built-in POI categories, only ones you add yourself. The full speed-zoned version of the PGPSW camera database only uses up 30 categories of your 169 available. |
