Pocket GPS World :: View topic - Copilot 7 freezes
Copilot 7 freezes
Drift
PostPosted: Sun Mar 22, 2009 4:37 pm    Post subject: Copilot 7 freezes Reply with quote
On my 02 Orbit2, I get as far as setting the route but when I hit the drive button the icon shows like its loading but just sticks then after a few minutes closes down, just once it loaded but 5 minutes into the journey it froze and shut down.
I cant think of anything Ive done to alter the settings.
It was interesting using an old paper map yesterday Laughing Out Loud.
Any ideas ?
Cheers.
Ste
Gone for simples and now have TomTom One V3 1gig
Memory Map V5 on laptop and GPS.
I couldnt get on with Copilot V8
alix776
PostPosted: Sun Mar 22, 2009 6:23 pm    Post subject: Reply with quote
it could be the device running out of memory make sure you have as little as possible running at the same time as cp7 is very memory hungry
device Lumia 950 xl
reteb
PostPosted: Sun Mar 22, 2009 7:50 pm    Post subject: Reply with quote
Not sure if it's the same problem I get, but I use CoPilot Live. Unfortunately, if you are in an area with an intermittent phone signal CoPilot shuts down soon after the signal is lost. The answer to this problem is to decrease the frequency that is used in the Live setup to something like 1 minute (or maybe switch off Live altogether).
Drift
PostPosted: Sun Mar 22, 2009 7:55 pm    Post subject: Reply with quote
I checked and I dont have any programs running when Copilot is running.
I very rarely use live as I get fed up of the icon popping up on the screen when it looses a signal and it wont go away, most frustrating.
Thanks.
Ste
Drift
PostPosted: Fri Mar 27, 2009 12:43 am    Post subject: Reply with quote
I had cause to hard reset my pda because of an unrelated problem, and bingo, it works fine after being re installed, thought might and didnt want to go down that route but another application forced me to.
Ste
Drift
PostPosted: Sat Jun 20, 2009 2:36 pm    Post subject: Reply with quote
A new twist to this, Ive found recently that when I use ALK EZP File (.ezp) (copied into the correct folder) safety camera updates, this causes the program to freeze up in the same way until I delete the safety camera file then it runs ok.
Does any one have a cure for this\/
Ste
nivek22
PostPosted: Sat Jun 20, 2009 7:54 pm    Post subject: Reply with quote
Try a soft reset prior to running coPilot to free up as much memory as possible.
Drift
PostPosted: Sat Jun 20, 2009 8:32 pm    Post subject: Reply with quote
Hi Niv, Ive done the soft reset, I also have a ram clean program but didnt make any difference.
Ste
alix776
PostPosted: Sat Jun 20, 2009 8:50 pm    Post subject: Reply with quote
it runs fine on my orbit 2 have you got this update ( i dont know if this is the same version as you are running) but it could be worth a try
click here
device Lumia 950 xl
Drift
PostPosted: Sat Jun 20, 2009 9:19 pm    Post subject: Reply with quote
Mine is only 6 months old with windows 6.1 professional xda Orbit11 so I should think that update would be already included? possibly.
Ste
alix776
PostPosted: Sat Jun 20, 2009 9:37 pm    Post subject: Reply with quote
are you using the copilot speed cams or or the pgpsw speed cams
device Lumia 950 xl
Drift
PostPosted: Sat Jun 20, 2009 10:28 pm    Post subject: Reply with quote
Ive been using the Copilot cams
Ste
alix776
PostPosted: Sun Jun 21, 2009 11:15 am    Post subject: Reply with quote
try the pgpsw ones ive not had a problem with them have you disabling the show pois from the map display
device Lumia 950 xl
Drift
PostPosted: Sun Jun 21, 2009 11:19 am    Post subject: Reply with quote
Ive not disabled poi, I only use the fuel station poi.
Not used PGPSW files as yet.
Ste
homecamp
PostPosted: Sun Jun 21, 2009 10:57 pm    Post subject: Reply with quote
Mine does that all the time. Crashes for no reason with no warning. Usually in the most awkward place. I've tried various ROM and Radio ROM on my Touch Diamond. There's plenty of RAM and space available. CPL7 is riddled with nasty bugs.
It especially hates it when it can't establish a GPRS connection for its Live or traffic feed. In some parts of the country with no mobile signal, I can't get CPL7 to start at all unless I manage to disable the traffic connection first.
I have tried raising this to ALK but they just don't care.
Not seen the camera problem. I use both databases but CPL7 crashes with and without the cameras.
Looking for an alternative to CPL7 before I throw my smartphone through the window.
22.051 (01 May 24)
