Pocket GPS World :: View topic - need a bit of help
need a bit of help
agdfry
PostPosted: Tue Jan 13, 2009 1:17 pm    Post subject: need a bit of help Reply with quote
Can anyone help with this i have tomtom one 3rd ed & so has my daughter but we cannot connect to both to the computer it is saying only one can be connected is there any way round this thanks for any help Very Happy
GerryC
PostPosted: Tue Jan 13, 2009 1:23 pm    Post subject: Reply with quote
If you are using Home on the computer, you will have to "log out" one before connecting the other. Hopefully, you have different email addresses set up for both units as this will cause problems otherwise.
If you are just backing them up or copying POIs etc, they can both be seen fine - they appear as separate drives in Windows Explorer though you'll have to be careful to know which is which. It's best just to connect them one at a time.
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
PostPosted: Tue Jan 13, 2009 1:41 pm    Post subject: Reply with quote
For TT Home, you MUST have two email addresses.
You can make each device recognisable by using its Splash Screen. How about His and Hers like this...
agdfry
PostPosted: Wed Jan 14, 2009 8:42 am    Post subject: Reply with quote
thanks for everyones help how do you do the splash screen ? Question
PostPosted: Wed Jan 14, 2009 11:51 am    Post subject: Reply with quote
Connect your device to the computer and shut down TT Home if it starts.
Use Windows Explorer to see on the device where the file splash.bmp is ignore these words in blue- it will be in the map folder (United_Kingdom_and_Republic_of_Ireland probably). Using Explorer, rename it to splashold.bmp
Then start Windows Paint and open that file. Add the text Hers wherever you fancy, in whatever colour you fancy (my own example is pure brilliance of course!) Then do File, Save As, and name it splash.bmp Ignore (just make sure that it is being saved into your map folder).
And that's the business! Make sure you disconnect the device PROPERLY from your computer by right clicking the drive it has connected at and selecting Eject - ON NO ACCOUNT just pull the USB plug out.
Edited to correct my stupid error. Just imagine the above without the words in blue. Thanks to Andy_P for pointing this out below. Embarassed
PostPosted: Wed Jan 14, 2009 7:02 pm    Post subject: Reply with quote
DennisN wrote:
Use Windows Explorer to see on the device where the file splash.bmp is - it will be in the map folder
Quack, Quack, Oops... Dennis Stupid
splash.bmp isn't in a folder, it's in the root / base level / outside any folder / where the system files are (call it what you will!)
Pocketgps
PostPosted: Wed Jan 14, 2009 8:37 pm    Post subject: Reply with quote
You can make/use your own or mod the existing.
Size is usually 320W x 240H x 24bit res
Save as .bmp format type which needs the name:
or
Do BACKUP your original ones first via Explorer.
PostPosted: Wed Jan 14, 2009 9:10 pm    Post subject: Reply with quote
Thanks Andy - duck egg all over my face. Embarassed
